350Z HR Y-pipe installed on a 2003 G35
Old Dec 28, 2008 | 11:47 PM
  #136
AARONHL's Avatar
Not sure that the 2007 G35 sedan has the Y-Pipe we are looking for. I checked it out at the dealership last time I was there and the Y-pipe didn't look like the same shape.
Old Dec 29, 2008 | 12:04 AM
  #137
chris12's Avatar
Originally Posted by RicoG35x
As a matter of fact, I have a G37 HR Y pipe on my 04 G35x sedan... and believe it or not... my Infiniti dealer hooked me up with it the last time I was in for some service.. very sweet! It was used stock from an owner that came in and had them install a custom exhaust system... so they "just happened to have it layin' around"! It's the same configuration as the 350Z, minus the hockey pucks... otherwise, the same pipe... with the same results! What a nice change of pace.. the dealer hookin' a brother up...
AARONHL - I added the G37 to the list based on the post quoted above.
Ricog35x - are you 100% certain that your y pipe is from a g37?
Old Dec 29, 2008 | 11:25 AM
  #138
AARONHL's Avatar
I said 2007 G35 sedan, go the the dealership and look underneath one.
Old Dec 29, 2008 | 04:38 PM
  #139
RicoG35x's Avatar
Let me DOUBLE check with my service guy.. I'm going in for a 4 wheel alignment later this week.. so I'll have him pull up the work order for this install and see EXACTLY what p/n they used...
I looks JUST like the big dog that DaveB had in his side by side shot comparing the old funky OEM pipe with the Z pipe he used.. WITH the exception of NOT having hockey pucks or even the brackets for them.. just clean pipes to the collector.
Old Jan 5, 2009 | 12:02 PM
  #140
CLyons0203's Avatar
is the revup y-pipe the same as the hr y-pipe?
Old Jan 5, 2009 | 12:35 PM
  #141
DaveB's Avatar
Nope. The Revup uses the old style y-pipe. It has to come from the HR motors.
Old Jan 5, 2009 | 01:09 PM
  #142
DaveB's Avatar
Well, I've figured out the purpose of the rubber/metal pucks. Once temps dipped below the 30s, I felt some rather significant vibration thru the seat when the car was cold. This only lasted about 2 minutes or so. I put the pucks back on and nearly all the vibration was reduced. Clearly these were designed to quell some odd vibrations the HR y-pipe creates when the motor/exhaust are cold. Once the car is warmed, pucks or not, the vibration is gone.
Old Jan 5, 2009 | 05:17 PM
  #143
gtrefever's Avatar
im still looking for a hr y pipe anyone know anyone selling one? some dude on my350z had one but he wanted WAYY to much he asking like 300 for it.
Old Jan 5, 2009 | 05:36 PM
  #144
4drmadness's Avatar
if you dont find one, just get a used aftermarket one man, like nismo, megan, stillen, or somethin like that
Old Jan 5, 2009 | 05:40 PM
  #145
AARONHL's Avatar
No, go with the HR only.
Old Jan 5, 2009 | 05:47 PM
  #146
gtrefever's Avatar
yeah thats what im thinking about doing if i dont find a HR.
Old Jan 5, 2009 | 07:36 PM
  #147
DaveB's Avatar
I'd have to agree. OEM fitment, OEM R&D, OEM quality, heavier gauge metal to keep heat in and exhaust velocity up, insulated to keep noise down, and most importantly, big flex sections to take the load off the exhaust and keep NVH down.
Also, I haven't read anything about people adding aftermarket y-pipes and seeing the type of "perceived" gains and improvements in drivability. What I've read about aftermarket y-pipes is rasp, increased NVH, and a low rpm power loss. I for one haven't felt any sort of loss and IMO, the driveability has improved in the low to midrange. I'd be the first one to tell you guys if I felt any sort of power loss or a negative impact on driveability. IMO, the HR y-pipe and Revup airbox have resulted in much improved drivability. Far more than I ever felt with the MD 5/16" spacer which is still a great mod.
Old Jan 5, 2009 | 09:42 PM
  #148
Dem1K's Avatar
I'd sell mine if I could get someone to give me their y-pipe + $$$
Old Jan 8, 2009 | 08:01 PM
  #149
gtrefever's Avatar
how much are you talking?
Old Jan 8, 2009 | 09:14 PM
  #150
Dem1K's Avatar
PM me if interested
