350Z HR Y-pipe installed on a 2003 G35
Old Apr 26, 2009 | 03:43 AM
  #451
MikeGrote's Avatar
in general, smaller piping with more back pressure will help low end power while sacrificing high end power, and larger piping will help high end power while sacrificing low end power
Old Apr 27, 2009 | 12:06 PM
  #452
Big C's Avatar
Here are the pics of the mysterious Y pipe I just took off my car after thinking it was a HR.
Stock DE pipe is on bottom.
Inlet from cat:
Outlet to exhaust:
Old Apr 27, 2009 | 12:16 PM
  #453
MikeGrote's Avatar
interesting...
Old Apr 27, 2009 | 01:29 PM
  #454
Jeff92se's Avatar
Red Card Crew
Whoa! Those downpipes are TINY!
Old Apr 27, 2009 | 01:40 PM
  #455
LightsOut's Avatar
SIETESG
guess size does matter
Old Apr 27, 2009 | 01:46 PM
  #456
DaveB's Avatar
That's a surprise.
Old Apr 27, 2009 | 01:53 PM
  #457
RicoG35x's Avatar
Obviously a new direction in flow dynamics design for these engines for Infiniti's engineering... wonder how the power curve maps out for this design...?
Old Apr 27, 2009 | 01:56 PM
  #458
AARONHL's Avatar
I'm pretty sure my inlets holes were bigger than that.
Old Apr 27, 2009 | 02:04 PM
  #459
Jeff92se's Avatar
Red Card Crew
This sedan? Because an article mentions the sedans were a few hp down from the coupes.
Old Apr 27, 2009 | 02:51 PM
  #460
UmassG35's Avatar
So the HR y-pipe diameter does not match the DE pipes coming from the cats? I know we're not looking to gain hp here, but isn't this a bad thing? Sort of bottlenecking.
Old Apr 27, 2009 | 03:07 PM
  #461
MikeGrote's Avatar
looks like they were trying to help out the low end power
Old Apr 27, 2009 | 09:25 PM
  #462
chris12's Avatar
BigC - What is the ID (inner diameter) of the inlet from the cat? It sure looks like a
G37/370Z Y pipe with the vibration dampeners removed. If it measures somewhere around 1.75" I'd say that's what you've got.
Old Apr 27, 2009 | 09:30 PM
  #463
ELMACHOGERACHO's Avatar
my money is on that being an fx y pipe
Old Apr 27, 2009 | 11:25 PM
  #464
Big C's Avatar
My car was noticeably slower across the board after installing that pipe pictured above. I was going to put my stock one back on but decided to just upgrade anyways and get the Motordyne XYZ pipe instead (which is awesome btw!!).
I can measure it tomorrow when I am back at work. 1.75" seems about right.
Old Apr 28, 2009 | 12:43 AM
  #465
DaveB's Avatar
HR y-pipe from the VQ35HR used in the 07-08 350Z does have the correct inlet diameters to match the DE cats and midpipe. Obviously something changed with the G37 coupe/sedan and possibly the 07-08 G35.
