Cold air induction
Old Nov 6, 2010 | 08:33 PM
the_sedan's Avatar
i wasnt saying hit it with 150psi. just enough to knock off the obvious dirt. but actually k&n says to take a brush and brush off any dirt/debris on the outside before using the cleaner and letting it soak.
Old Nov 6, 2010 | 09:14 PM
KNC97's Avatar
That's pretty much the procedure of the DIY's I've seen while researching this today. I was ***-uming you just replace them, but my bad I guess. I'll get a cleaning kit and get on it. Thanks
Old Nov 7, 2010 | 07:07 AM
grovefromnh's Avatar
The AEM CAI on my car uses a dry K&N filter. Apprently the oil in the older filters was being sucked into the throttle body, leaving a fine coating.
Old Nov 7, 2010 | 07:27 AM
N80's Avatar
N80
That makes sense. My last K&N was on top of a Weber.
Old Nov 7, 2010 | 08:17 AM
Project's Avatar
Its not a K&n though its the popcharger. Like someon else said get the twenty dollar cleaning kit. Slightly tap to remove the dirt into the garbage then goto town. Make sure you let it "air" dry all the way out. Then lightly apply the oil. To much and it will coat the maf sensor and make your car act up.
Old Nov 7, 2010 | 08:18 AM
Project's Avatar
Oh rinse from the inside out and dont use a knife or anything to pry into the grooves you will rip the filter.
Old Nov 7, 2010 | 08:55 AM
KNC97's Avatar
Ya know, on second thought, I might just say f*** it and buy a new filter . Since it has no part# or even brand name anywhere on it, and was on the car when I got it, I can't really determine if it's a dry filter or one that needs to be oiled. Instead of paying $20 for a cleaning kit and not be sure about it, I'll just pay the $50 for a new one for the peace of mind.
Old Nov 7, 2010 | 09:36 AM
N@eem's Avatar
I have a brand new filter for sale, pm me for price
Old Nov 7, 2010 | 11:42 AM
herrschaft's Avatar
^^Your gonna have to clean that one eventually too.
Old Nov 8, 2010 | 07:22 AM
M302_Imola's Avatar
OP I hope you don't live in a warm part of the country because without a heat shield that induction system has heat soak written all over it! You might check into getting just the heat shield.
Old Nov 15, 2010 | 10:27 AM
KNC97's Avatar
I'm in MD, so heat isn't a huge issue here.
KruZZe
Feb 27, 2023 05:04 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
