Rough Starting After Wolf Intake Install
Old Feb 6, 2011 | 10:20 AM
smeres's Avatar
2004 Auto G35
Coincidental or not....A few weeks after I installed my Jim Wolf intake system and it got really cold out my car has been starting rough. Here are my 2 issues:
Turn Key
Engine Starts right up at 2K rpm
Rpm Immediately then drops to .25-.5K rpm - almost stalls
Then increases rpm and seems fine
Turn Key
THEN STALLS
This only happens After the car has been sitting for a while with cold engine.
It stalls out even more when I am parked on a hill for a while and start it on an incline with a cold engine.
Please help. I ordered a mass air flow sensor last week but am having second thoughts if that it the issue.
Help!
Old Feb 6, 2011 | 10:22 AM
Project's Avatar
Your throttle body is dirty. Also it would help to clean your MAF with some cleaner since the popcharger is oiled. You probably just have some pulled in on it.
Old Feb 7, 2011 | 12:31 PM
HYDRUS's Avatar
Same happened when i installed mine. Cleaned the maf and throttlebody and it started back up like a champ.
Old Feb 7, 2011 | 10:24 PM
T3K_V35's Avatar
03' track... Soon to be race car.
Exclamation
Be very very careful when you clean them.....its really easy to mess both of those parts up, and they are both expensive
Old Feb 22, 2011 | 06:39 PM
smeres's Avatar
Took my G to the dealership for some professional advice. They ran a test on the MAF and seemed to read fine. Ran a second test on the throttle body and BINGO....bad readings. $609.00 later and a new throttle body....car runs great!
Old Feb 22, 2011 | 09:20 PM
MM_G3520's Avatar
Why did you do that? No, I'm not talking about wasting your money on a poop charger, but the dealership? Damn, that was not the best choice. You could've swapped it out yourself. I doubt it needed to be replaced anyway.
Old Feb 22, 2011 | 10:19 PM
sTeadFasT96's Avatar
Honestly I had the same issue a while back and all it was is that I forgot to plug in the MAF sensor.
Old Feb 22, 2011 | 10:50 PM
Blue Dream's Avatar
I drove ttrank's car solo
That sucks. For $195 and an allen wrench you could have bought a new TB and had it changed out in 30 minutes.
And it still would have run great............
Old Feb 27, 2011 | 10:35 AM
Jstache23's Avatar
What cleaner would u use for both? MAF and throttle body.
Old Feb 27, 2011 | 11:28 AM
smeres's Avatar
I was told CRC Works Well:
http://www.crcindustries.com/auto/co....aspx?PN=05110
http://www.crcindustries.com/auto/co...x?PN=05078&S=N
Old Feb 27, 2011 | 01:33 PM
jicenroa's Avatar
wow, i forgot to plug in the tube on the back of the z-tube caused my same issue, and i cleaned the throttle body with spray and it went back to normal, 600.00 WOW
chinee
Jun 10, 2024 07:48 PM
ghost_g35
Aug 7, 2015 10:31 AM
Terry_G35
Aug 4, 2015 02:38 PM
itschuckster
Jul 25, 2015 08:07 AM
