PPE Engineering LongTube Headers
Old Dec 20, 2011 | 11:34 AM
  #151
Dsskyline's Avatar
check out the dyno of their 370z headers that has the step in almost the same location as SG. The drop is in almost the same area as those SG dynos.
notice the step location on the 370z headers and SG compared to mine. Actually their 370z headers are designed similair to the SG the step and merge location is different compared to mine.
http://my350z.com/forum/intake-exhau...longtubes.html
www.ppeengineering.com (search under 370z in products)
I think with our car the further back the step the later the drop occurs due to the distance the wave has to travel. SG found the right location for our car. http://thehorsepowerjunkies.com/gene...epped-headers/
Everyone of those SG setups are different, but the drop occurs between 2-3k in all of them while mine starts at 3k.
Old Dec 21, 2011 | 09:26 AM
  #152
gabe3d's Avatar
Sure. He is the intercooler I am going to be using for my car.
This is the bottom mounted sc location for the rotrex.
Other then the sc itself I am also going to be running direct port water infection. can't wait for this thing to be done. Hopefully early January.
I was gonna post some pics of the sam but looks like you found some pics already.
Old Dec 21, 2011 | 10:08 AM
  #153
Dsskyline's Avatar
GTM is making your SC? What is the reason to bottom mount it. Looks good!! I may be interested if it performs and not as loud as a vortech.
Old Dec 21, 2011 | 10:15 AM
  #154
PR-G35Driver's Avatar
I want this to be a production sc plz!!!!!! lol gabe is their an estimated power output with your awesome built block???
all this right here will determine if I go big with my block na wise.....knowing that your engine will hold will make me take the leap lol
Old Dec 21, 2011 | 10:31 AM
  #155
Dsskyline's Avatar
Gabe what size pulley (psi) will be on your kit? What are you expecting out of this kit over the Vortech, Stillen, and HKS SCs.
I bet the HP of the Vortech, Lowend TQ of the Stillen, and near silent operation of the HKS.
Old Dec 21, 2011 | 09:41 PM
  #156
gabe3d's Avatar
GTM is making the supercharger for me, hopefully us.
The reason for the bottom mount is to get rid of the jackshaft system found on both the HKS and Vortech kit.
I have no doubt in my mind that it will be much quieter then any of the vortech blowers. A few other platforms uses this blower and have reported excellent operation quietness.
Once I get it back with the SC, which is hopefully soon, i will surely let everyone know about the results and outcome. I don't expect it to be wimpy
I'm thinking on at least 9psi but it all depends on how my car takes the boost with the water, so I won't know for sure until GTM puts the car thru its pace. My overall expectation is to gain a good chunk of power everywhere while still having the car drivable on the street.
I'll contact GTM again to see if they have some more eyecandy for us
Old Dec 22, 2011 | 10:33 AM
  #157
Dsskyline's Avatar
That's good info I wonder if any issues being bottom mounted for a 5at?
Old Dec 23, 2011 | 12:50 AM
  #158
JuicinJake's Avatar
that rotrex blower looks incredible... supposedly the best of both worlds. i used to really want a turbo, but lately ive been leaning towards a more conventional hot rod setup: blower, nitrous, cams and gears. i hope the gtm de kit is readily available.
Old Dec 28, 2011 | 05:19 PM
  #159
Dsskyline's Avatar
Originally Posted by skidz88
According to JWT they don't need head clearancing, it's only the C9 cams that do. Kelford would have been my second choice for cams.
Just found out my headers shipped out today as well.
Did you receive your headers yet?
Old Dec 28, 2011 | 07:55 PM
  #160
skidz88's Avatar
Still waiting. Stupid USPS doesn't seem to update their tracking info very often. Still says the same thing since the 22nd. I'm hoping they arrive by Friday.
Old Jan 5, 2012 | 10:18 AM
  #161
skidz88's Avatar
Headers are in, pics tonight
Old Jan 5, 2012 | 06:53 PM
  #162
Dsskyline's Avatar
Nice!!! Alot of peanuts huh?
Old Jan 7, 2012 | 08:54 AM
  #163
skidz88's Avatar
Yea, had to fish around in the box for the O2 extensions lol.
Old Jan 7, 2012 | 01:09 PM
  #164
Dsskyline's Avatar
Nice!! Looks good black.
Old Jan 17, 2012 | 09:30 PM
  #165
rich2342's Avatar
Originally Posted by Hydrazine
I can't say for sure, but I don't think its the voltage.
Here is why.
1) 0.1V out of 5V is much too small to make that kind of a change on the curve. That's only a 2% variation of voltage.
2) The power curve delta is more than 2%.
3) Even if the TB is 2% closed, a 2% closure won't create any appreciable pressure drop across the TB valve unless the RPM's are high. But the RPM's were low.
4) The TB voltage goes to 5V at a different RPM than where the power curve shows recovery. If the power curve recovery RPM coincided with the voltage recovery RPM then it would suggest a correlation, but they don't. RPM of each event is different.
5) If you changed the TB and still get the same results, its not the TB.
Did you monitor the spark advance during the testing? If for some reason the knock sensor picked up some kind of noise it could pull back timing.
But for some reason, and I've seen the same type of effect before during my ART pipe experimentation, when I look at your power curve, it seems like its simply a signature of the acoustic resonance tuning. I did the same thing in the early stages of tuning the ART pipes. Some of my early ART pipe testing was actually much worse.
The only way to really know why you have a loss of low end TQ is to put it all back to the pre-test condition.... but I fully understand this is not something anyone would want to do unless they have lots of time and $$$ to burn.
Does anyone Tony etc, know if it's req'd to install headers with cams? I want to add JWT S1's based on Sg motorsports results. I have an 03 DE M/D 5/16 spacer HFC's and Exhaust tuned with Uprev. Would i be likely to gain the stated 15-20whp from cams only being added and tuned with Uprev?
