PPE Engineering LongTube Headers
Old Jan 18, 2012 | 12:29 AM
  #166
PR-G35Driver's Avatar
^^ i spoke to sasha at sg about the same thing when i got my long tube headers from him. on the non revup version its a must to benefit from the headers like the revup does. just installing the headers he said u can still see gains in the power band depending on the upgrades you have already and also that just because you have all the bolt ons doesn't mean all the bolt ons work in conjunction with each other....if one isn't doing its job correctly it can hold back the rest of the breathing mods.
Old Jan 18, 2012 | 02:48 AM
  #167
Hydrazine's Avatar
Originally Posted by rich2342
Does anyone Tony etc, know if it's req'd to install headers with cams? I want to add JWT S1's based on Sg motorsports results. I have an 03 DE M/D 5/16 spacer HFC's and Exhaust tuned with Uprev. Would i be likely to gain the stated 15-20whp from cams only being added and tuned with Uprev?
Not required but there is certainly an interaction between the two.
I don't know what your results will be though.
Old Jan 18, 2012 | 07:59 AM
  #168
Dsskyline's Avatar
Nice avatar pic do you have more pics from that shoot?
Old Jan 18, 2012 | 08:26 AM
  #169
here's one
Old Jan 18, 2012 | 12:05 PM
  #170
Hydrazine's Avatar
Old Jan 21, 2012 | 02:46 AM
  #171
Dsskyline's Avatar
I think I found out my lowend issue. My floor mat!!
My floor mat slid under my acc pedal preventing my acc pedal from being fully floored.
The metal ring on my mat tore off alowing it to slide under my pedal.
The pedal felt like it was floored, but was not. WOT voltage for the acc pedal is between 4.3-4.5V and for the TPS 4.12-4.16V as tested on other cars. Mine varied between 3.5-3.9V for both.
The voltage should go instantly to 4.3-4.5V APP sensor and 4.12-4.16V for TPS. My car did not do that, now it does with the mat moved from under the pedal.
0V= -17% 5v=120% so every volt is about 24% open ( I guess )
The revs pick up faster now in the range which showed my power loss before it was laggy. I plan to get dynoed soon to be sure once the weather here gets better.
Old Jan 21, 2012 | 02:51 AM
  #172
SDGenius's Avatar
haha, ain't that some ****
Old Jan 21, 2012 | 03:02 AM
  #173
gabe3d's Avatar
Do you have a prius?
Old Jan 21, 2012 | 03:07 AM
  #174
t6378tp's Avatar
Sometimes it's the stupidest things
Old Jan 21, 2012 | 03:50 AM
  #175
Dsskyline's Avatar
maybe it's a toyota pedal. The coupes do have something to prevent it from sliding on the driver's side.
My metal ring tore off that attaches to the hook in the floor.
Old Jan 21, 2012 | 07:45 PM
  #176
skidz88's Avatar
Omfg are you kidding me?
Old Jan 21, 2012 | 08:14 PM
  #177
Dsskyline's Avatar
No, because I have sport pedals which are a little longer than stock the bottom was catching the moved mat.
Well at least it is hopefully solved. PPE was going to make me a different set of headers with no step.
Old Jan 24, 2012 | 05:02 PM
  #178
DSK559's Avatar
Price for a set?
Old Jan 25, 2012 | 09:53 AM
  #179
Dsskyline's Avatar
$850-$1k depending on coating.
Old Jan 25, 2012 | 10:12 AM
  #180
JuicinJake's Avatar
floor mat!!! haha... u r gonna break 400rwhp on the bottle for sure
