PPE Engineering LongTube Headers
Old Feb 7, 2012 | 12:40 AM
  #226
JuicinJake's Avatar
lookin good... u guys still have me on my toes regarding the fixed floor mat dyno... i just ordered my tdx2 today... cant wait to hear it!
Old Feb 7, 2012 | 12:43 AM
  #227
PR-G35Driver's Avatar
you'll love them man best exhaust sounding note and power.
Old Feb 7, 2012 | 06:13 AM
  #228
Dsskyline's Avatar
Dyno will be this Friday at RT tuning to confirm that my issue is solved. I'm seriously thinking about switching my Gemini for the TDX V2.
Old Feb 7, 2012 | 09:51 AM
  #229
MikeGrote's Avatar
cant wait for numbers
Old Feb 7, 2012 | 02:55 PM
  #230
Dsskyline's Avatar
Here is a dyno I've done recently at Hill's garage after my floor mat fix. This dyno is comparing my dyno without LTs/Cams to now. I did the before in 2010.
I also included pics showing the difference in top end between the two.
There are no lowend losses, i've also included my last RT dyno to compare.
I want to go back to the original dyno that showed the losses since I did the before on RT's dyno for a fair comparison.
Remember this a DE with cams similar to SG's they used Nismo's. So a non-cammed DE may not see similar gains.
topend before LTs and Cams compare at 6700
Topend after LTs and Cams compare at 6700
Hills dyno after removing floor mat (blue line is a N/A run not a nitrous run)
RT Tuning dyno with mat under pedal.
Nitrous 125 shot using NX nozzle vs 100 shot using ZEX nozzle vs NA Best time so far on juice 12.3@114
Old Feb 8, 2012 | 12:23 AM
  #231
JuicinJake's Avatar
well, problem solved... 289 whp DE? yep, they are gonna get my money. w00t!!!
Old Feb 8, 2012 | 01:22 AM
  #232
SDGenius's Avatar
^don't forget the cams
Old Feb 8, 2012 | 02:12 AM
  #233
JuicinJake's Avatar
yea cams for sure... still trying to decide which ones though. a lot of that dictates whether i will keep the mrev2 and spacer or sell it and go revised cosworth... decisions...
Old Feb 8, 2012 | 10:43 AM
  #234
VoBoy's Avatar
Nice....
Old Feb 8, 2012 | 11:17 AM
  #235
Dsskyline's Avatar
Yes and a 6mt would have more due to less drivetrain loss. I have mild cams compared to you what you may get so you should gain more.
I originally ordered Kelfords, but the earthquake damaged their facility in NZ. So I had to change to JWT. Didn't want anything too lopey which I don't have with the S1's.
Old Feb 8, 2012 | 09:15 PM
  #236
rich2342's Avatar
Impressive gains.. I want to do Cams on mine with HR buckets, just dont want Headers. Wonder what my gains would be.
Old Feb 8, 2012 | 09:47 PM
  #237
Dsskyline's Avatar
Probably 15-20 depending on what cams you get. I'll ask RT to give me a dyno sheet comparing before cams and after.
I remember my before was 250hp after was 269hp on RT's dynojet.
Old Feb 8, 2012 | 10:53 PM
  #238
gabe3d's Avatar
Good to see you resolved your problem. Hopefully you see teh same on RT's dyno, but i'm sure you can already feel the difference just by driving since the loss was so huge. Told you that the Prius swap was a bad idea.
Btw, didn't you have the momentum headers when you installed your cams?
what's the difference in the two runs here?
Old Feb 9, 2012 | 12:10 AM
  #239
Dsskyline's Avatar
nothing Vince really tried to tune out the lowend drop by adding fuel and timing just a before and after of what he did. Once my issue was resolved I was 12.1 in that rpm range at Hills Garage.
That dyno is with longtubes I dynoed 269 with the momentums and cams with less midrange than the longtubes.
Old Feb 9, 2012 | 02:17 PM
  #240
Vegas4DR's Avatar
no dyno from pre/post floormat issue right?
