07 g35x P0507
Old Feb 23, 2023 | 07:23 PM
BrawlinCam's Avatar
I drive a Metallic Silver 07 G35x with the VQ35HR motor
07 g35x P0507
So I’ve been dealing with this issue for a few days now, when I first purchased the car I noticed the idle use to sit at 800 rpm and I discovered a gaping hole in the left side air intake hose which I replaced… P0507 was also happening but it would disappear on its own. I noticed the RPMs dropped to about 750 so I then decided to clean both MAFs and both throttle bodies… i sprayed the passenger side TB with CRC cleaner and didn’t move the butterfly door. I then moved to the left side TB moved the butter fly door and sprayed it with Tb cleaner. When I went to start the car it began idling around 950RPM-1200RPM and it hasn’t gone down ever since. I tried the pedal dance multiple times only for the engine light to flash slowly then fast like it was actually doing the idle relearn and then the SES light flashes slowly again and goes full solid… car still idled high. I then decided to take it to my mechanic and he told me that I needed a new throttle body which I forked up $485 for and it still didn’t fix the problem. The left side TB was definitely shot though. I disconnected the battery overnight for about 15 hours started the car again and it still didn’t relearn the idle. So I then brought it back to to my tech and he went through the relearn again changed the passenger side TB did a smoke test to check for any leaks but no luck his scanner still couldn’t execute the relearn. So now I’m stuck and I wanted to know if the android app NDSII or NDSIII may help me fix my issue that I’m having? Please help me out!!!!!!
Old Feb 25, 2023 | 02:37 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
So you have the HR engine which would require NDS3, I THINK it can do the idle air recalibration but I'm not completely sure since I haven't actually used it. Maybe someone else with an HR engine like @treacherous can chime in if they've had any experience with NDS3 app.
Have you checked your PCV valve and the various PCV hoses to make sure they're not cracked/loose/leaking? Sounds like you may need to smoke test your intake to look for any other leaks.
Old Feb 25, 2023 | 03:15 PM
treacherous's Avatar
20 Year Member
G35x
Sorry.. unfortunately have never used NDS3
Old Mar 5, 2023 | 12:17 AM
BrawlinCam's Avatar
NDS did the relearn after driving car for a few days
So I replaced my left throttle body & the car didn’t do the relearn. At this point I started losing hope & I made an appointment with the stealership and was planning to get my ECU reflashed. I drove the car for about 2 weeks and the SES light would go on & off over and over but I noticed instead of the car idling at 1100rpm like it was before I noticed the indie dropped to 800-850 rpm & I said okay as a last ditch attempt lemme try NDS again and do the IVAL relearn since the car is idling under 1K. I plugged in my cheap $13 Bluetooth obd scanner and ran the program. Immediately the car rpm’s went down then back up to about 900 then dropped down to 650-700 rpm and stayed there. Maneeeee I was so happy I been dealing with this is issue since I first bought the car it was idling at 800 rpm. And with a simple android app it fixed it opposed to me going to the Stealership and paying $300 to flash my ecu
Old Mar 5, 2023 | 10:04 AM
cleric670's Avatar
BANNED!!!
Glad you got it all sorted out.
Pete2734
Oct 1, 2018 11:27 AM
ka8man
Jul 26, 2018 05:39 PM
rkim210
Southern California
11
Feb 8, 2011 10:15 PM
alexh521
Jan 12, 2011 08:51 PM
maomao
Dec 21, 2008 06:46 PM
