350Z duct & Stillen Hi-flow
Old Oct 23, 2003 | 11:27 AM
  #61
cliverman's Avatar
Re: 350Z duct & Stillen Hi-flow
Question is....are you feeling dizzy from the gases from the engine compartment? : )
Seriously, how are you measuring the temp?
Old Oct 23, 2003 | 01:41 PM
  #62
DaveO's Avatar
cliverman,
To check temperatures I use my calibrated index finger and...
Please note the lazer pointer (red dot) on the collector. This readout is after the car had set for 30 minutes so it doesn't mean much.
I checked the collector, under cover and air duct temperatures immediately after doing two back to back G-Tech runs on my local "Test Track". The collector was 126F, the undercover temperature was 164F and the air duct's external temperature was 122F with the engine at idle.
Yes it's accurate... at least it's real close (usually identical) to my garage liquid in glass thermometer.
DaveO
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
DRG35R
Jan 31, 2016 07:14 AM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
