G35 Coupe Headlight Removal Guide (3 Simple Steps)
Old Jun 5, 2007 | 03:09 PM
  #61
shdowflare's Avatar
Bulb replacement
Check out this link for more info on how to swap out your headlight bulbs:
https://g35driver.com/forums/lighting/134414-diy-s-replacing-low-beam-clearance-strip-bulbs.html
Originally Posted by ac419
sorry i'm a newb.. i want to install my philips hid 6k bulbs. what is the best and easiest way to install them? thanks.
Old Dec 17, 2007 | 01:45 AM
  #62
O HELLA OEM's Avatar
nice
Old Dec 17, 2007 | 06:00 AM
  #63
importroller's Avatar
^^for some reason I cant view that link in your post
Old Jan 12, 2008 | 02:27 PM
  #64
328is's Avatar
I have the same question! After getting the casing open with baking (or a hair dryer as i've done in the past), where can we buy a clear circular marker for the signal? Also, how are the parking lamp stripes so bright and led looking in these pics?
I've been scouring the forums day and night for an answer to these questions so pleasee help, i wanna get it done soon....thanks.
Old Jan 12, 2008 | 02:32 PM
  #65
328is's Avatar
How do you do the Clear signal replacement
After getting the casing open with baking, where can we buy the circular clear marker to replace the signal?
I've been scouring the forums day and night for an answer to these questions so please help, i wanna get it done soon....thanks.
Old Jan 12, 2008 | 03:12 PM
  #66
LCA575's Avatar
The strips are from here:
http://automotivelightstore.com/inde...ROD&ProdID=105
The clear lenses are from the same place but no link, sorry.
Old Jan 12, 2008 | 03:15 PM
  #67
sfgr415's Avatar
For the clear lenses, you can buy fluorescent lighting diffusers from Home Depot and just cut it to fit.
As for the strips, they are CCFL and require much more work than simply replacing a bulb.
Old Jan 13, 2008 | 04:50 PM
  #68
I couldnt find it on the site, how do you order it then?
Old Jan 14, 2008 | 09:30 AM
  #69
shdowflare's Avatar
Links should be working now...
Old Jan 29, 2008 | 10:12 PM
  #70
calcul8's Avatar
I can haz potato?
sabertooth tiger
Great write-up!
Old Feb 12, 2008 | 02:08 AM
  #71
sfgr415's Avatar
Originally Posted by calcul8
Great write-up!
yes it is.
Old Mar 29, 2008 | 01:01 PM
  #72
citymunky's Avatar
Here's mine
BTW: It that a stove in the there??
Old Apr 19, 2008 | 08:45 PM
  #73
burgerG35's Avatar
what exact bulb are you using for your corners? They looks nice and white.
Old Apr 26, 2008 | 02:42 AM
  #74
328is's Avatar
Demon Eye AAC kit install question
Pics FIXED
I'm nearly finished with the demon eye install for the AAC kit. The instructions say to "thread the wires (from inside the housing) behind the reflectors and out the 'parking light' hole in the clearance strip." Being that there is a bulb and socket in the clearance strip, does anyone know how we are to put the wires through?
In other words, how did you guys run the wires from inside the sealed headlamp housing to the outside where the converters are? Thanks a bunch.
Old May 5, 2008 | 12:49 PM
  #75
LCA575's Avatar
Its not a bulb, its actually a CCFL strip.
http://www.automotivelightstore.com/...ROD&ProdID=105
Also, there is now a video as well for the installation of the halos that can be seen here:
http://www.automotivelightstore.com/...n=Custom&ID=31
