OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Aug 3, 2010 | 12:06 AM
  #1531
CG4DR's Avatar
Rolled for sure. If you rub on a cut fender you will shred your tires.
thats what i was thinking but i don't think i want to go to the extreme. i just want something a tid bit more aggressive than my Z wheels. Maybe a 9.5'' in the rear with a 20-30 offset..
Old Aug 3, 2010 | 12:15 AM
  #1532
SN00P's Avatar
CLUB MODERATOR
the tool was only 56.52 and was worth it :-) i should have it by aug 15th the latest ... im going to see what this thing can do...
Old Aug 3, 2010 | 12:17 AM
  #1533
SN00P's Avatar
CLUB MODERATOR
if you like the wheels just add some spacers on there .. its cheaper and you can make that set up semi aggressive for little money ... :-) ill have the pincher for the front when you'll need it and will take the car to adrian for some fender cutting and boom you'll be set .. the way i see it is if you rub a little in the back add some camber :-)
Old Aug 3, 2010 | 12:18 AM
  #1534
CandlestickPark's Avatar
ill Sedan
That sounds good. 9.5+20 with a 255/35 and ~3 degrees of camber will require a very flat roll.
Old Aug 3, 2010 | 12:25 AM
  #1535
SN00P's Avatar
CLUB MODERATOR
what would be a decent semi aggressive offset with my 245 and 265 marcus till i get some new tires end of the year ... without pulling front and rear ...
Old Aug 3, 2010 | 12:35 AM
  #1536
ill Sedan
8.5 +20 / 9.5 +20 (or+ 25 if you don't want to run more than 3 degrees of camber)
Old Aug 3, 2010 | 12:36 AM
  #1537
kennymo's Avatar
what are you rim widths?
Old Aug 3, 2010 | 12:43 AM
  #1538
Fabrikator's Avatar
not sure what my camber is at yet, i still have to get an alignment, buts prob in the neighborhood of -4.X...
gonna cut polish my car next weekend, and my friends gonna do a photoshoot, ill post up again with some better pics =)
Old Aug 3, 2010 | 01:30 AM
  #1539
CG4DR's Avatar
i know my LR camber is at -2.6 right now so I want to stay around that since its my DD. Fronts are sitting at an even -1.2 so if this helps anyone help me that would be awesome. i would like to stay with a 225 in the front and possibly a 245 rears..
Old Aug 3, 2010 | 01:35 AM
  #1540
SN00P's Avatar
CLUB MODERATOR
just get your rears cut ... and a 5 or 10mm spacer on the back fix the camber up with the camber kit and you should be flush as can be :-)
Old Aug 3, 2010 | 01:47 AM
  #1541
CG4DR's Avatar
i don't want a spacer. i want different rims.
Old Aug 3, 2010 | 09:16 AM
  #1542
Matzo Ball's Avatar
quick blackberry pics from this AM. A little flushness and a little poke for the rear......19x8.5 +15 (w/ 10mm spacer) on 255/35/19s. Rolled as flat as possible. Not as aggressive as others, but works for me Front will come down a touch and then will go +5 or +10mm more
Also, time for a RRYDE grill (or someone else that can do it )
Old Aug 3, 2010 | 09:20 AM
  #1543
Matzo Ball's Avatar
pretty much. 8.5 +15 w/ 255s and I am flat as possible.
Old Aug 3, 2010 | 09:23 AM
  #1544
4DGS's Avatar
I've been considering getting a company I know to make injected versions of the emblemless grille for sedans.
Hmmm
Old Aug 3, 2010 | 10:41 AM
  #1545
NjMatteSedan's Avatar
So it looks like I have to cut my fenders sooner than planned. 1 of my rear tires shredded a couple weeks ago and I bought a new one different brand same sizes. The deal was too good to pass up and the sidewall sticks out more and sit really flush compared to my old toyos looks as if I put a 10mm spacer on. I'm rubbing really hard on that side
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
