OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Aug 8, 2010 | 01:45 PM
  #1681
SN00P's Avatar
CLUB MODERATOR
i should be the only snoop on driver :-)
Old Aug 8, 2010 | 01:46 PM
  #1682
kennymo's Avatar
unless snoop dogg buys a g35
Old Aug 8, 2010 | 02:58 PM
  #1683
4drmadness's Avatar
Old Aug 8, 2010 | 03:01 PM
  #1684
CandlestickPark's Avatar
ill Sedan
^So proper!
Old Aug 8, 2010 | 04:01 PM
  #1685
Matzo Ball's Avatar
I agree, and the paint is great. Looks black, dark grey, brown, golden depending on the light.
Old Aug 8, 2010 | 05:00 PM
  #1686
SN00P's Avatar
CLUB MODERATOR
PERFECT !!! i love the new set up
Old Aug 8, 2010 | 10:12 PM
  #1687
Matzo Ball's Avatar
Need to dial in a bit more camber. Was rubbing a touch on corners. At -2.6 now. Thinking about -2.8. Thougths? 19x8.5 +15 w/ 255/35 now.
Old Aug 8, 2010 | 10:42 PM
  #1688
ill Sedan
I was at 9.5+20 with a 255/35 and -2.75 degrees of camber, which is 8mm more aggressive than 8.5+15. How flat your roll is, your tire brand and how stiff your shocks are will be factors that would contribute to you rubbing. I would dial in a bit more camber or get a flatter roll since I believe you are on springs and can't adjust your dampening.
Old Aug 9, 2010 | 09:53 AM
  #1689
Matzo Ball's Avatar
Running Kumho ASX and dont have much stretch, so the normal sidewall is probably causing the rubbing. I am as flat as I can go out back. My shocks are OEM so I get a decent amount of shock compression.
Old Aug 9, 2010 | 10:40 PM
  #1690
Matzo Ball's Avatar
also wondering if I should go 5mm more out back. May look odd w/o a good stretch and not being slammed. -2.8 camber tomorrow.
Old Aug 9, 2010 | 10:53 PM
  #1691
Johnnyone's Avatar
why would u add spacers when u are already rubbing? and I would go -3 n the rear, going from 2.6 to 2.8 isnt gonna b that much different.
Old Aug 9, 2010 | 11:00 PM
  #1692
CG4DR's Avatar
johnny are you planning on making a trip to FL anytime soon? lol i need some fender rollage
Old Aug 10, 2010 | 09:43 AM
  #1693
Matzo Ball's Avatar
I add 10mm spacers and realigned the rear and have very minor rubbing. I could go 5mm more and just add even more camber
Old Aug 10, 2010 | 11:01 AM
  #1694
Johnnyone's Avatar
I do need a lil vacation...i'll roll them for ya if you get half of my plane ticket lol...
I see, personally i wouldn't add the spacers and more camber. IMO spacers and camber is only needed if you have an aggressive drop. With that said camber will be added with an aggressive drop.
Old Aug 10, 2010 | 11:16 AM
  #1695
forweareLegion's Avatar
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
