OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Jan 18, 2011 | 05:12 PM
  #2821
Sonicteam120's Avatar
Cool
Originally Posted by toymachine2009
what spacer should I throw on these rears to make them more flush
19x9.5 +35
255/35 tire
what rims are those
Old Jan 19, 2011 | 02:34 AM
  #2822
TycoRC's Avatar
Infiniti G35 Sedan Nismo Aero Sport Package
Originally Posted by The Stimulation
I've been doing a bit more research into the Achilles tires that Vivek has since I'm in the market for new ones and I've been getting some personal opinions about them rather than what I read on some forums.
They're rounded so they'll provide more clearance (than the Hankooks) and they stretch well. Apparently several of the Platinum VIP guys run them. I think I'm gonna try out a set of 245/30's. If they can stretch on the 11, might be a new and inexpensive tire option. Hopefully I can get the tires mounted by Saturday.
But then again Lev, Vivek doesn't drive it daily. I would rather run Nexens than Achilles, I run mine daily and I have no issues. Then again Platinum VIP guys, well most of them run air ride suspension, so tire contact is not an issue to them for you, running on the side wall daily man I'd be scared
Old Jan 19, 2011 | 02:42 AM
  #2823
Equipped4dr's Avatar
But then again Vivek has a "Daily Driven" sticker on his rear window
Old Jan 19, 2011 | 02:46 AM
  #2824
TycoRC's Avatar
Then again Vivek has all that tire contact when he hits the switches
Old Jan 19, 2011 | 02:51 AM
  #2825
oh thats right
Old Jan 19, 2011 | 02:59 AM
  #2826
TycoRC's Avatar
Lev I say its time to do some airbags or hydros or air cups
Old Jan 19, 2011 | 10:55 AM
  #2827
The Stimulation's Avatar
HEEEEEEEEEEEEEEEEEEELL NO! Nevear!!!!!!!!!!!!!!
Platinum VIP cup kit is the furthest I'll go, but static is the way to roll. Next setup I won't have to worry about extreme negative camber. Prob be around -5 or -6. By that time I'll have a widebody and radiused fenders. Or something along those lines. Wheels will clear just barely within the fender. Only reason why i'd do the cup kit is because unlike bags it uses 100% of your coilovers when not in use. And they're meant to be driven not in use, even though you can drive with it aired up. I'd only use for extreme cases.
I love daily driving my car and people asking if I'm on bags and then getting the surprised look that it just lays low like that.
Also, this time around I'm looking to get more clearance from the tire, running a little more stretch. If I can do that, then I can solve the tire rubbing issue. If the stretch doesn't fix things, then more negative camber will.
Are the nexens rounded or squared tires? I'm also considering Triangle tires. Heard they stretch well too.
Old Jan 20, 2011 | 10:34 AM
  #2828
Get_some35's Avatar
Any pics with them stretched?
IMG_9941.jpg?t=1295537434
235/35 on a 10.. if i remember correctly haha
Old Jan 20, 2011 | 11:01 AM
  #2829
Lol. Gotta be a 19, right? Cos I tried ordering the 235/35 in 20 and they don't make it. I ended up going with a 245/30. Turns out they do run a little small. They're smaller than hankooks based on some pics i found. I'll be getting the fires mounted on the wheels tomorrow so we'll see. Thanks for the pic!
Old Jan 20, 2011 | 12:13 PM
  #2830
Hotdawwgman's Avatar
There was a guy on my350z telling me that the Achilles tire was great for stretching.......
Old Jan 20, 2011 | 12:25 PM
  #2831
Most of the cheaper tires are great for stretching because of the lack of reinforced sidewall. A lot of guys run tires that most people would normally look over (nankang, nexen, achilles, traingle, diamondback, etc). Then again there are some that people would buy (hankook, toyo, some falkens, etc).
It's so good that cheap tires work well with stretched application. People say they spend 1k+ on tires and here I'm spending <500. You can literally get new tires mounted and balanced in the high 300's to low 400's for 20's. How awesome is that?
Old Jan 20, 2011 | 09:37 PM
  #2832
dz n.u.t.z.'s Avatar
Yea I bought my two fronts "20's" for 100 bucks apiece brand new. "GOLDWAY"'s lol they seem to be holding up good. But rawr like a dump truck. Lol
Old Jan 20, 2011 | 09:40 PM
  #2833
I'm debating on not being so hella flush in the front and just being as hammed as possible. Or raising it a tad and leave the spacers on? Hmm. 19's was easy. But 20's u got to do work. Also got fully Poilshed wheel houses in the rear. Lol
Old Jan 20, 2011 | 09:51 PM
  #2834
CandlestickPark's Avatar
ill Sedan
Cliff you've always been more agressive up front than the rear IIRC. You can afford to go 5mm (or 10) less aggressive up front, will still look very sick.
Old Jan 20, 2011 | 10:31 PM
  #2835
Yea but then it sunk in lol I think I have been so use to the flush look, it just look weird any other way. But I have to make up my mind before I fix the fenders.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
