High Engine Oil Consumption Rates
Old 03-02-2008, 09:37 PM
accordhybrd's Avatar
Andy that's good to hear, sounds like it might be time for a twisty run. You and I should see who can burn the most oil in one trip.......haha
  #197
Old 03-02-2008, 11:11 PM
Andy2434's Avatar
Thanks, guys . . . We'll see what happens. I really want to keep this G as my daily driver.
  #198
Old 03-02-2008, 11:20 PM
frog's Avatar
i checked my oil today its at half on the dip (about 3.5k miles) so my guess is no consumption for me /phew some luck finally...
btw MG35Coupe did u ever get your shifter fixed? when they replaced my tranny/clutch i had a similar problem where 5th gear wasnt top right, it was more of a top right, half inch to the left, then up. ended up the gear box or something was crooked they fixed it no questions asked now its good as new .
  #199
Old 03-07-2008, 07:17 PM
Andy2434's Avatar
Originally Posted by V35 Skyline GT
That's good news leak issue is behind you. I agree with dealer in taking off catch can. In a healthy non OC VQ, you shouldn't need one anyway, imo.
Hope it's a winner now leak fix.
Interesting observation for you, John, I have driven my car some 200+ miles since the oil leak resolution. I took the oil catch can off after the fix and as requested by the dealership. Since that time, the car has light engine ping/knock at light throttle.
LMAO . . . I guess I can monitor the OC via the vapor by-pass, which is probably causing the light pinging, since I cannot physically see the oil in the catch can anymore.
  #200
Old 03-08-2008, 12:39 AM
Kris79's Avatar
battle froggy
lol maybe they turned up ur timing to burn all the oil off instead of going to the tube
  #201
Old 03-08-2008, 01:00 AM
Andy2434's Avatar
^ lol...your never know with dealers. I got played bad at my first OC test level reading
Andy...check to make sure your not sucking in any air from hoses where catch can was. Sucking air = lean = ping and turns into vicious cycle with others aspects of pinging causes.
Yeah, I checked and rechecked the PCV and lower intake plenum connections. To be quite honest, the pinging does not surprise me at all. The catch can was filling up quicker than it was with the original engine. So, with the oil catch gone, all of the oil vapor is simply re-entering at the intake plenum and breaking down the gasoline's octane level.
  #202
Old 03-08-2008, 01:02 AM
^ Ah gezz...light pinging
Well check that stick at ~500mi and 1000mi to see what's up with your level. Hopes it's still at full for your sake now leak is gone.
And/or screw dealer and put catch can back on, shhhhh
Your not in testing anymore, or are you? I forget.
But in all respects, you shouldn't require one really for normal operation.
Have a few tricks up my sleeve of recent knowledge obtained. Well talk next time we see each other again
I want to know of the learned knowledge
  #203
Old 03-08-2008, 01:07 AM
Kris79's Avatar
battle froggy
u mean when thye painted ur dip stick to show u arnt buring oil hahaha
  #204
Old 03-08-2008, 01:12 AM
Andy2434's Avatar
Oh Ballz...that's not good news......
Yeah that's what mine doing and has for awhile, but I had found a leak, fixed and pinging reduced but not completely gone.
Damn it Andy...this is not the news I wanted to hear on your behalf
Damn it, John, that it not the news I wanted to tell you.
. . . But I still have my sense of humor.
  #205
Old 03-08-2008, 01:14 AM
Kris79's Avatar
battle froggy
hey since ur pinging u can use 87 now lol
  #206
Old 03-08-2008, 01:17 AM
Andy2434's Avatar
I like your turn a bad situation into a positive one attitude, nephew. Here, let me reach out and slap you across the top of your head.
  #207
Old 03-08-2008, 01:20 AM
Kris79's Avatar
battle froggy
cant let things get u down, always loook at the brighter side. it could also mean u can get water injection now lol or better yet those cool nos octane boosters hahahah
  #208
Old 03-08-2008, 01:26 AM
Kris79's Avatar
battle froggy
if i had oc it would just give me a reason to rip it apart and build the sucker. lol4.5 stroker!!!
  #209
Old 03-08-2008, 01:27 AM
Kris79's Avatar
battle froggy
btw i think i am going stroker instead of super charger
  #210
Old 03-08-2008, 02:03 AM
Are you serious Kris, what are the gain differences from s/c to stroker?
Quick Reply: High Engine Oil Consumption Rates
