Engine Bay Pics*Post here*
Old Feb 22, 2010 | 04:20 AM
  #1906
biggz786786's Avatar
^did that after i took the pics haha
i was just wondering if its possible to paint everything that is plastic in the engine bay? like the air diversion panel and the plastic part that connects to the bumper and reservoirs? i know the battery and brake cylinder cover can be painted
Old Feb 23, 2010 | 04:36 PM
  #1907
Skaterbasist's Avatar
Retired SuperMod
I'm thinking of using my Manufacturing System Engineering laboratory for engine bay part polishing. Hopefully I can get clearance from my professor.
Old Feb 23, 2010 | 04:48 PM
  #1908
GreenGoblin's Avatar
The goblin resurrection
I forgot to ask him, but I will call him tonight to get the answer. I want to say the place was in Alabama.
Danny
Old Feb 23, 2010 | 07:31 PM
  #1909
DrewTheSuit's Avatar
can someone walk me through the installation of the pi-thon hose locks...the radiator locks and 2 smaller ones near those...do they simply slide over the hoses and tighten down with the wrenches, or is more complicated such as draining fluids etc?
Old Feb 23, 2010 | 07:44 PM
  #1910
SxExCx's Avatar
You need to drain the fluid at least below the lowest level of that hose. You can do this by using a hand-pump / siphon through the radiator cap.
Old Feb 23, 2010 | 07:58 PM
  #1911
that's what i thought, but wasn't sure...any idea about how much fluid will need to be removed to get it past that point? approximately a pint, quart, etc?
Old Feb 23, 2010 | 11:31 PM
  #1912
SxExCx's Avatar
A little over a pint should do it. Just pull about that much out then unclamp the side of the hose that connects to the radiator (the higher side). Once you slide that side off, you can hold it up and see how much more you need to drain out before you can pull the other side off.
Old Feb 24, 2010 | 02:56 PM
  #1913
http://www.customcoatings.net/
This is the place that chromes plastic and fiberglass parts. They did my old boss's cbr tail section (plastic), and a buddies prowler grill (fiberglass).
Old Feb 24, 2010 | 03:53 PM
  #1914
bigc's Avatar
Wings Nation
thanks Danny!
Old Feb 24, 2010 | 05:56 PM
  #1915
OCG35's Avatar
thanks for the link... good source
Old Feb 26, 2010 | 01:26 AM
  #1916
Big Rob's Avatar
Never gone
Originally Posted by PhantomIPG
...something a "little" different!
Well, it's about time!
It looks great, bro! I love it! So clean!
Me next, mmkay?
P.S. Looking forward to seeing you & the boys on Sunday!
Old Feb 26, 2010 | 02:13 AM
  #1917
PhantomIPG's Avatar
You know it, brother!
...see you soon and thanks!!
Old Feb 26, 2010 | 12:03 PM
  #1918
where can i get those colored washers? do i need new bolts?
thanks
Old Feb 26, 2010 | 12:16 PM
  #1919
SxExCx's Avatar
^ebay and yes, you need to but new bolts.
Old Mar 2, 2010 | 07:35 PM
  #1920
sean can't seem to find a siphon, do you think a turkey baster would work to drain some of the fluid from the radiator
