Reviews Reviews of specific modifications, posted by members
Motordyne Plenum Spacers, Non-RevUp Engine Feedback
Old Jan 27, 2006 | 06:14 PM
  #196
1badmax's Avatar
Originally Posted by Dan_K
Is this the mrev or just the regular spacer?
I have the ISO thermal 5/16" spacer for the non-MREV motor. The MREV is only for the 298hp M/T G35's.
Old Jan 27, 2006 | 07:14 PM
  #197
Gaaaar's Avatar
Originally Posted by ratedxmarcel
I thought the 5/16 shows best power gains on the dyno?
Actually the 5/16 has better power throughout the rpm range, but if your talkin about racing someone or tracking your car. You'll be spending most of your time near redline, so the 1/2 spacer is actually better.
Old Jan 27, 2006 | 07:22 PM
  #198
g35rcr's Avatar
its only a few hp difference...the 5/16ths makes more usuable hp
Old Jan 27, 2006 | 08:48 PM
  #199
Mr_pharmD's Avatar
Yup this is soo true. I think 1/2 shines mostly at the top end so good for long distance run
Old Feb 1, 2006 | 11:06 PM
  #200
Asumis51's Avatar
So is this basically a general consensus that the 5/16" provides a better output of power in that it is across the powerband rather than large gains towards the peak 5.5k+ rpms of the 1/2"? I was going to get the 1/2" iso thermal but if this is true, then I may have just decided to go with the 5/16". Do the gains or sound differ much between these two or are they basically the same? The 1/2" claims 12-14 hp while the 5/16" claims 11-13; is this peak power or throughout since many have said the 5/16" provides more power throughout? Thanks!
Old Feb 1, 2006 | 11:22 PM
  #201
6969g35's Avatar
From: FROM BROOKLKN NEW YORK NOW LIVE IN VALENCIA CA.
any problems like ex. idle
with the spacer
Old Feb 11, 2006 | 03:17 PM
  #202
eledin's Avatar
I don't have many mods yet, but I've been extremely pleased with the spacer. It was a noticeable difference with no negatives at all.
Old Feb 23, 2006 | 08:48 AM
  #203
DY1's Avatar
DY1
I think I'll limit my "mods" to performance tires and sway bars. As has been stated the G's engine is highly tuned from the factory. The aftermarket NA engine gains are not much....
Old Jun 19, 2006 | 11:34 AM
  #204
darnelled's Avatar
I added the Motordyne spacer lsat week along with 10 wire grounding kit 350z-tube and K&N filter. Install was easy and took about 1 hour for the spacer. After ECU reset, there was quite a noticable improvement in power and acceleration throughout all RPM's. The car is 5-AT 2005 sedan and finally feels like the car I'd hoped for when buying it. It is definately a worthwhile mod that can be done by someone with minimal mechanical skills as long as you follow the excellent directions.
Old Aug 20, 2006 | 04:21 PM
  #205
hoolamonster's Avatar
1/2 spacer
I wouldn't go as far to say my car is faster but the sound is great! easy install!
Old Aug 20, 2006 | 07:35 PM
  #206
Calvin's Avatar
Overglorified Altima
wow old thread lol
Old Sep 3, 2006 | 09:57 PM
  #207
trbospnkr's Avatar
Thanks for the info.
My question is did you get the mrev plus? Because from what I have been hearing. I've called motordyne myself and they pretty much said that its for sure that you'll gain 10-15whp through the power band and lose about 2whp at high rpm's. I have been doing alot of reading concerning our motor and it seems like it's pretty much finely tuned already, I question these mods and for the sake of power increases. Wonder which mods will work? for a second I was ready to make my purchase with the mrev plus but now I'm kind of skeptical. Thanks for the info. I also have an 05 and looks like my hks exhaust, cai will be it for now.
Old Sep 28, 2006 | 08:14 AM
  #208
Hondahawaii777's Avatar
Co-signed. Good question, bump for confirmation/answer.
Old Sep 28, 2006 | 09:39 AM
  #209
6969g35's Avatar
I agree with you...
Old Oct 28, 2006 | 09:55 AM
  #210
clinthammer's Avatar
ive ordered the 5/16 iso thermal with aramid gasket and ccv. Will have a local garage install it. They have done similar installs on 350z's.
My question is - since i am in the Middle East (Dubai) where temps are between 28C to 49C should I leave the ccv open or closed?
Winter months are oct to feb where the temp is 28 to 36c and summer is march to sept where temps rise from 36c to 50c.
Cheers,
Clint
