Reviews Reviews of specific modifications, posted by members
Motordyne Plenum Spacers, Non-RevUp Engine Feedback
Old Oct 29, 2006 | 04:44 PM
  #211
Gordgee's Avatar
Administrator
Originally Posted by clinthammer
ive ordered the 5/16 iso thermal with aramid gasket and ccv. Will have a local garage install it. They have done similar installs on 350z's.
My question is - since i am in the Middle East (Dubai) where temps are between 28C to 49C should I leave the ccv open or closed?
Winter months are oct to feb where the temp is 28 to 36c and summer is march to sept where temps rise from 36c to 50c.
Cheers,
Clint
If you don't need coolant flow to warm the throttle body since it never gets cold there, you could leave it closed year-round.
Old Nov 4, 2006 | 06:46 AM
  #212
clinthammer's Avatar
Well I had a garage install the motordyne 5/16 spacer today in my 06 g35 sedan and i have noticed the difference. The pickup of the car is much faster as it flies to the 4k rpm easily.
The install was done easily - with me nagging the tech since he only installed the skunk spacer on a 350z. Anyways all went well - we did not install the aramid gasket because, as he said , your car is one month old so there is no need for it now.
So i only had the plenum spacer installed and the tech forgot to attach a coolant tube. i started the car and darn coolant was leaking in. stopped it and had it fixed.
Now I gotta get my engine washed because im a picky owner and want it clean everywhere.
simple install and great upgrade.
Old Nov 4, 2006 | 06:18 PM
  #213
Gordgee's Avatar
Administrator
What does the car being 1 month old have to do with him not installing the aramid gasket? The idea behind the replacement gasket is that it thermally isolates the lower plenum from the top of the engine so that the lower and upper plenum runs cooler!
The labour involved would have been minimal while everything was apart. To add it after would require taking apart everything again!
If I were you, I'd go back and have them do it right.
Old Nov 5, 2006 | 12:18 PM
  #214
Hydrazine's Avatar
Hmmm. +1
I think the guy was being lazy. He should have installed it for you. It would have been so easy from that point. And the instructions show how to do everything.
Do you think he can install it without additional charge? If you think he might, you should nag him to do it.
BTW - Congrats on the results!
Old Nov 5, 2006 | 01:42 PM
  #215
O HELLA JDM's Avatar
haha got confused by this long *** thread...but hope you enjoyed your results... i think thats correct
Old Dec 21, 2006 | 08:49 PM
  #216
s2k_g35's Avatar
have any one install this on an 03 or 04?
Old Dec 22, 2006 | 12:44 AM
  #217
Gordgee's Avatar
Administrator
Mine's on an '03. I think most of the reviews here are from '03 and '04s.
Old Dec 22, 2006 | 02:27 PM
  #218
ryn996's Avatar
I installed my 5/16 motordyne spacer with aramid gasket yesterday. I didn't do the coolant control valve because down here in FL it doesn't get below 55 degrees enough to warrant the install. I have an 04 5AT coupe with 32,000 miles. It took about 2.5 hrs. Mostly because I took my time but I did get ahead of myself a few times and had to take some things apart to install some pieces I forgot. I did the gas pedal ECU reset afterward and haven't had any problems. I noticed a small increase in acceleration in the lower rpms and a little bit better in the higher rpms (above 3000). The engine is slightly deeper now but not very noticeable. All in all I'm happy with the changes. Big thanks to Tony at Motordyne, he is a really nice guy and very easy to deal with. I won a $250 Motordyne gift certificate at an event in Tampa called The Run and Tony walked me through how to buy the spacer with the gift certificate. Great guy and a great product, I recommend it.
Old Mar 10, 2007 | 06:53 PM
  #219
burn's Avatar
My 5/16 Iso is on it's way right now (Thanks again, Tony).
I've also been looking at the ztube+popcharger setup. I've heard that this, in combo with the plenum, will make me run too lean, etc. Can any of you drop any knowledge on this subject?
BTW I have an 05 5at
I'll be sure to describe my install experience as soon as I get it done next week.
Old Mar 10, 2007 | 08:40 PM
  #220
ma_sha1's Avatar
Before going FI,
I have bought & sold MD 1/2 spacer due to not seeing any gain at track.
After the MD spacer, I've had lean signals logged ~30 times at dealer after taking the car in. After removing the spacer, the lean signal went away.
I blamed it on the spacer back then. Come to think about now, I believe there is a more logical explaination with
knowledge gained on how the G controls AFR during my FI journey.
The spacer will give more air, no doubt, However, most people add spacer, intake, cat back etc. ( I had cat back & Z-tube before adding spacer) never do any tunning. All these mods, especially spacer may create a lean condition. Once the ECU detect the lean condition, it'll retard timing causing the car to lose power, all of a sudden, the what supposed to be a gain becomes a loss.
Simply put, same spacer mod, the power gain seen by some may be a power loss by others depends on what other Air breathing mods are on the car & if the lean condition is being detected by ECU.
To optimize the spacer mod, there are several ways to go:
1, Remove other air breathing mod, do you really want to do that?
2, Reflash ECU to program it with the increased air. ~$500
3, Get a piggy back ECU & do a tunning, most expensive.
4, Get a slightly bigger fuel pump. -most economical way to go,
adding fuel pump does not require tunning.
Stock fuel pump is 90lph, most FI use 255lph pump.
With a few air mod, I believe a ~130-160 lph fuel pump may help to balance out the air mod, stay away from lean condition & gain back the lost power.
I have just upgraded my HKS fuel pump (Came with the HKS S/C, rated 140-160 lp) to a 255 lph fuel pump. So my HKS fuel pump is up for grabs,
anyone wants to try it with your spacer mod, I'll part with it for $79 shipped.
This fuel pump is rare, there isn't another fuel pump upgrade small enough could be used for NA mods, the smallest I've seen is 190 lph. PM me if want to try it.
Old Mar 26, 2007 | 05:50 PM
  #221
infinitialex's Avatar
I have an 03 Auto Sedan with intake and skunk2 spacer
I am suspecting that i have lost low end and top and torque and power with the skunk 2 5/8 spacer install
Old Oct 12, 2007 | 12:26 PM
  #222
ShanesG's Avatar
motordyne 5/16" spacer
Just installed this last night and wow, its an awesome mod, i can def feel the difference. I Def. recomend it.
Also soon to come in the next week or so
20mm spacers for the rear
Tein Basics
Old Oct 12, 2007 | 12:45 PM
  #223
Yv12345vY's Avatar
How hard was the install? I'm thinking this will be my next engine mod.
Old Oct 12, 2007 | 12:50 PM
  #224
joe603's Avatar
The MREV2 is the next mod to do....Wow, what a difference! I would suggest doing them both at the same time. The plenum spacer is really easy, the only thing you need is a torque wrench. The MREV2 lower plenum isn't hard, it's just more involved.
Trust me....it's worth the money!
Old Oct 12, 2007 | 12:53 PM
  #225
ShanesG's Avatar
i thought it was gonna be hard, so i had my buddy do it at his shop, but it was accually really easy, we took our time and it took like an hour and a half
