TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Infiniti Rev-Up Oil Consumption TSB
Rating: Thread Rating: 4 votes, 3.75 average.
Old Mar 21, 2012 | 06:04 PM
  #1756
kasher_khan's Avatar
Quick update - Shortblock replacement
Dropped my car at the dealer last fri. Got call today saying they were still working on it (something about machining some parts). Said it should be done by Monday.
Old Mar 21, 2012 | 06:35 PM
  #1757
DGrantG's Avatar
Nice.. Did they give u a loaner?
The vm I received said it was approved and to bring my car in on Tuesday.
Old Mar 21, 2012 | 07:44 PM
  #1758
Yes. Have a loaner since last Fri. My dealership is great about that.
Old Mar 21, 2012 | 08:01 PM
  #1759
DGrantG's Avatar
Yeah I'm getting a loaner too. I'm hoping for an M but it'll prolly be a G37 sedan. When I took my car in the first time they gave me a loaner too.
Old Mar 28, 2012 | 09:14 AM
  #1760
DGrantG's Avatar
I dropped my car off yesterday morning and my loaner turned out to me a '10 G37 Sedan. Man these things have some power!!!
I'm having them replace the clutch, spark plugs and do a fuel injector cleaning service on the car as well. Alls I have to pay for is the clutch and the spark plugs, they're doing the labor for free!!!
Hopefully I can pick my car up this afternoon or tomorrow.
Old Mar 28, 2012 | 09:19 AM
  #1761
Texasscout's Avatar
How much for the clutch? I was quoted $2000 two years ago. That's crap. I got a JWT clutch pack and had it installed for $1200
Old Mar 28, 2012 | 09:32 AM
  #1762
DGrantG's Avatar
$500 for the clutch kit and $60 for the throwout bearing. Labor is 8 hours, according to the dealership. But I figured since they're in there, I'd just have them replace it b/c it was needing it anyways.
Old Mar 28, 2012 | 09:34 AM
  #1763
DGrantG's Avatar
Just checked and the JWT clutch is $485... so I'd just rather have OEM. I don't plan on doing major stuff to my G, at least right now.
Old Mar 28, 2012 | 09:58 AM
  #1764
NGK's Avatar
NGK
4 months later!!!
so, just thought I'd share the saga that was my oil consumption issue....in a nutshell:
(started Nov, 2011)
1st stealership did a short block and butchered it completely. Cracked the head, leaking oil, etc, etc...
infiniti consumer affairs sent a Tech inspector
2nd dealership did a complete longblock in 3 days - runs like a top
whole process took 4 months , I now have the beauty seen in the photo below! yes, I need to clean my intake...
everyone is right in trying to get the longblock - they couldnt seal my timing cover, routed things wrong, and cracked the head (covered with JB weld!) , etc, etc - try for the longblock, its pretty too
NGK
NGK
Old Mar 28, 2012 | 10:08 AM
  #1765
buzzking's Avatar
(started Nov, 2011)
NGK
NGK
Got a short block on mine last December.
No oil leaks, but not sure how to check if there are any problems...
Old Mar 28, 2012 | 10:22 AM
  #1766
NGK's Avatar
NGK
Mine were pretty easy to spot....oil leaks, missing nuts/bolts, and cables routed wrong...plus a glob of JB on top of the head...
Old Mar 28, 2012 | 10:23 AM
  #1767
buzzking's Avatar
If I post a pic of my engine bay tonight can you help me spot anything wrong?
Old Mar 28, 2012 | 11:38 AM
  #1768
NGK's Avatar
NGK
i'll try! but if you've had it since LAST december (10, or 11?) over a year, i wouldnt worry too much...however this past december - its worth checking....
one easy way is to drop the plastic cover on the bottom of car (bunch of 10mm bolts) and look for any oil spots on the cover, and also on the bottom of the block
Old Mar 28, 2012 | 12:28 PM
  #1769
buzzking's Avatar
I got it done Dec/2011.
I took the plastic tray off my car a while back because it won't stay on.
I'll start with checking for signs of oil leaking.
What parts of the engine should I remove besides the engine cover before taking pictures?
Old Mar 28, 2012 | 01:32 PM
  #1770
Texasscout's Avatar
Did that include the clutch, pressure plate, throw out bearing, SS clutch hose, pivot bearing, and new pivot ball?
You have already rated this thread Rating: Thread Rating: 4 votes, 3.75 average.
