TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Infiniti Rev-Up Oil Consumption TSB
Rating: Thread Rating: 4 votes, 3.75 average.
Old Apr 15, 2008 | 06:35 PM
  #166
123G35's Avatar
Originally Posted by V35 Skyline GT
^ Odo mileage continues on. It can't be reset back to zero.
Oic...thanks for the info.
Old Apr 17, 2008 | 10:40 PM
  #167
PrayingMantis's Avatar
Originally Posted by slikmo22
Not sure if anyone mentioned this, but since this is such a common problem with the VQ motor's how will replacing the motor with another VQ solve the problem?
Because the new VQ received a new piston and new rings to handle the "higher revs" the new REV-UP engines were made to do.
Previously, those dumb **** at Nissan decided to up the REV w/o upgrading the INTERNALS to handle it... What kinda dumb DeVRY Graduates are they hiring over there at Nissan?
Even fuking Honda knew that increasing the REV-LIMITS would do damage to the internals if they didn't upgrade it.. Which why is the internals of an LS is different then a GS-R..
Old Apr 18, 2008 | 09:45 PM
  #168
g35coupe35's Avatar
Originally Posted by g35coupe35
At ~7,900mi, I took my G35 coupe 6MT to Infiniti dealership when I started hearing a knocking noise and noticed that the "check engine" light would come up every few times a week. I was called in 4 more times after that (every 1000mi) specifically for oil-level testing. The dealership received an approval to replace the engine, and at 14,500mi, after just about 6 months, I drove out with a new one (10102-AC7M9). I was told to go easy for the initial 12-15K.
After driving about 1000mi now, I am running low on oil. I just checked it myself. I plan on taking it to the dealership soon to record it formally.
But this is not the only problem I am having, the new engine seems to be a lot louder and a bit sluggish too.. yes.. definitely not the ride I got used too!!
I would like to hear from users who have been through the replacement and thier findings.
How should I approach this problem now?
Got a replacement engine this year.
If anyone is interested.. here is my post story:
first 1000-1500k oil test according to TSB -- verdict "LOW"
.. filled up oil ..
Now I am at 2200k (1000-1500k testing #2) -- I checked oil levels and nothing has changed.. still way too LOW
Anyone here got a lemon claim filed? Any results?
Old Apr 18, 2008 | 09:47 PM
  #169
shdowflare's Avatar
What year's ur ride?
Old Apr 18, 2008 | 09:49 PM
  #170
g35coupe35's Avatar
06mt
Old Apr 19, 2008 | 12:36 AM
  #171
Drv4fun's Avatar
Originally Posted by Drv4fun
Well, it sounds like I'm headed back to the dealership for the OC issue. I had my test done last November and the documented OC was 1qt/2300 miles (well into the not ok section).
In addition to this, I'm now having synchros issue. I get some grinding sound shifting into 5th gear every morning. It seems to go away after about 20 minutes into the drive but never had that before.
Man... do I have a case under the Lemon Law? I wouldn't mind trading mine for the new G37... :-)
Just an update... took mine back to inquire about my original OC issue.
So the service guy says I need to redo the test... blah, blah, blah. Though I wasn't happy, I agreed. Well, he calls me 4 hrs later saying that they'll go ahead and replace the engine. Apparently, they had an engine available to do the swap.
Things to note after I received the car back:
Since this is a new engine, it will require another break-in period. 1200 miles w/o going over 4000 RPM.
They don't reset the mileage. It stay on whatever it had when the repair was done.
The standard warranty doesn't restart. It just continues like before.
Now, regarding the 5th gear grinding.... Their "analysis" is that I needed a new clutch. They said that's causing the issue. Since I didn't really research this as much, I agreed to have them replace the clutch for $400. Now, if this was truly a clutch issue, won't it NOT shift on any gear? Bastards!
Anyway, with my $400 spent, I still have grinding issue shifting into 5th gear. Headed back there next week and give them a piece of my mind.
Old Apr 19, 2008 | 01:44 PM
  #172
sharkman's Avatar
Can someone please tell me if this oil problem exists on the 08 G35XS?
thanks
sharkman
Old Apr 20, 2008 | 01:31 AM
  #173
Horrible... Just horrible. I don't drive the G as much and theres no way I can come up with 1-2 for the test.. I'll just let my bro drive it.
Old Apr 25, 2008 | 10:00 PM
  #174
LightsOut's Avatar
SIETESG
when i had grinding in 5th gear i took it to infiniti of montclair, they new exactly what it was and replaced my tranny.
Old Apr 26, 2008 | 12:22 PM
  #175
V35 Skyline GT's Avatar
6MT Coupe
thanks
sharkman
You have the next generation VQ block that appartly doesn't have this plague.
^The most recent TSB this thread pertains to and what years/models are affected.
Old Apr 26, 2008 | 12:35 PM
  #176
sharkman's Avatar
thanks...
sharkman
Old May 2, 2008 | 01:08 PM
  #177
Startbutton99's Avatar
06mt
I had my engine replaced around 30k im at 45k now..
the car did feel sluggish inthe beginning but after almost 10k.. it became what it used to be.
however my unlike u, my OC issue seems to be resolved.. sorry to hear bro.
Old May 2, 2008 | 01:28 PM
  #178
twin001's Avatar
Infiniti called me the other day, new engine is on order. I hope this resolves my issues. I wonder if they would let me buy back the old engine, or even just block. I would like to build it for FI. I'm really liking the Power Lab ST kit.
Old May 2, 2008 | 01:39 PM
  #179
6MT Coupe
Wouldn't hurt to ask about buying old one, but have read from other members and Z members too, that they send it back for the engineers to assess why it failed.
G/L and hope your replacement is a winner.
Old May 4, 2008 | 10:40 AM
  #180
stephenw's Avatar
hey all. first post.
i'm really happy this forum exists. i wouldnt have know about this issue w/o it. so thank you.
i just bought a '05 g35 couple w/ manual transmission. so my car may have an OC issue. i've started my own OC test to see whats what.
i have a few questions for you guys from things i've read in this thread...
1. what does VQ mean?
2. what does rev-up mean?
3. i've had cars that consumed oil before. granted the engine should not do that, it was otherwise mechanically sound. i just had to monitor it. is that the case for these motors? if my motor does have an OC issue, but it doesnt fall in the 'No Good' range... is it that big of deal?
thanks for any info.
You have already rated this thread Rating: Thread Rating: 4 votes, 3.75 average.
