TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Infiniti Rev-Up Oil Consumption TSB
Rating: Thread Rating: 4 votes, 3.75 average.
Old Mar 6, 2008 | 12:53 AM
  #106
V35 Skyline GT's Avatar
6MT Coupe
^ I'll can say is that the current replacement VQ #10102-AC7M9 became available back in June/July 2007.
If memory serves, the TSB only covers G's that were made prior to May 31st and that VIN you stated.
Pure assumption and guess here, but imo possibly they started using the #10102-AC7M9 VQ in production starting June1, 2007 where the TSB cut-off date is.
Just guessing but makes sense to me that's why the cut-off date and VIN range compared to when the revised VQ became available.
Old Mar 6, 2008 | 01:22 AM
  #107
G35-Jat's Avatar
Hmm, I guess its a hit or a miss then, would suck to get a 06 g35 with oil consumption issues, although still under warranty it would be a PITA.
Old Mar 6, 2008 | 02:19 AM
  #108
6MT Coupe
True statement...hit or miss with the revup VQ 6mt unfortunately. Roll of the dice, being I have an 06 6mt with moderate OC
Old Mar 11, 2008 | 11:20 PM
  #109
ZeeForce's Avatar
Hey guys, TSB was amended for the 350z on 2/27/08. I believe the G was also amended. I em'd V35 Skyline GT to confirm with Infinit's TSB.
Here is the post on 350
http://my350z.com/forum/showpost.php...postcount=2709
Old Mar 12, 2008 | 01:51 AM
  #110
6MT Coupe
Yup Infiniti amended theirs too, dated the same as 350Z one. ITB08-002a for Infiniti.
All they changed was the OK/NO GOOD chart.
They eliminated the 0-500 and 501-1000 mile replacement qualification columns.
Glex25, PM me or I think you know where to go for this TSB to post up as .pfd
Or here it is. Grab and put on your first post.
INFINITI G35 OC TSB REVISED 2-27-08 ITB08-002a.pdf
Old Mar 15, 2008 | 07:36 AM
  #111
twin001's Avatar
I just started the OC test with my dealer. I have only put 350 miles on it so far. They wanted me to come back at 1000 miles but I think I'll take it in at 1499......I'm still playing by the rules
What type of motor oil have your dealers been putting in during the OC tests? My dealer put in Mobil1.
Old Mar 15, 2008 | 12:08 PM
  #112
ivory05coupe's Avatar
My dealer put in Mobile 1 also back in October when i had the OC test done. I brought it in after 2000 miles and it was 2.5 quarts low. I just got the car back 2 weeks ago with the new motor and its running great.
Old Mar 18, 2008 | 02:37 PM
  #113
SR20DET510's Avatar
Finally getting my new engine!
Took 5000 miles of tests to finally have a new engine.
I was doing the original consumption test and I was short 1 quart every thousand miles. On my 3000 mile test Infiniti switched the test and they were now measuring in mm. I was not tested at 3000 miles because I was having my oil changed and the original level reading was not documented.
I was told to wait and did, just returned from the oil consumption test and I was at 26mm below the original reading. Does anyone know what that is equal to in quarts?
I was told my reading was off the chart as it list up to 24mm if I remember correctly.
Do I get a new 60000 powertrain warranty?
Can I have a new clutch installed when the engine is being switched over?
Old Mar 18, 2008 | 05:23 PM
  #114
shdowflare's Avatar
I was wondering the same thing - how does mm equate to quarts low? And do I get a new powertrain if/when I get a new long block?
Old Mar 18, 2008 | 06:17 PM
  #115
6MT Coupe
Smart way to play the TSB game. I'm playing like that too.
As far as what type on oil during OC testing, I've heard some use Synth and some insist on Dino. Got mine to use Synth, Castrol 5w-30.
.....I was at 26mm below the original reading. Does anyone know what that is equal to in quarts?
The TSB shows how many mm's equal between H and L.
H to L = 1qt = 24mm's.
Talk to your SM about warranty. You don't get a new or extended by default with replacement. If you don't ask, no chance in possibly getting one.
Clutch...again talk to your SM. Since your VQ will be out, don't see why they can't do that. They might cut you a deal on clutch replacement labor hours too
Old Mar 18, 2008 | 07:04 PM
  #116
shdowflare's Avatar
So according to the TSB, the dealer considers an engine for long block replacement if it burns at least one quart in 3000-3500 miles? That's what I read from the oil consumption chart in the latest TSB.
Old Mar 19, 2008 | 11:13 AM
  #117
6MT Coupe
^ That is correct. And if over 24mm down between 3501-3750mi, qualifies also.
Old Mar 19, 2008 | 11:33 AM
  #118
shdowflare's Avatar
Thanks - since I'm burning 4.5 qts. every 3000 miles I should be good.
Old Mar 19, 2008 | 01:09 PM
  #119
twin001's Avatar
GOOD??? I think you mean good for a new engine! That is a lot of oil to be burning up in 3000 miles. I hope a new engine is under your hood soon
Old Mar 19, 2008 | 02:49 PM
  #120
shdowflare's Avatar
Yep that's what I meant! Starting the OC testing soon so I'm thinking a new VQ35 would be really GOOD...!
You have already rated this thread Rating: Thread Rating: 4 votes, 3.75 average.
