TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Infiniti Rev-Up Oil Consumption TSB
Rating: Thread Rating: 4 votes, 3.75 average.
Old Jun 10, 2008 | 09:25 AM
  #226
Gcoupe06's Avatar
Just an FYI: I'm getting my engine replaced - I'm up on my third test and service advisor guaranteed that my engine will be changed. The first test, it was consuming 26mm of oil and second results came with 27mm. My third test should be in by next month.
Information on this thread has been very helpful. I'll make sure to ask for new belts and plugs, in case they don't already.
Old Jun 10, 2008 | 12:49 PM
  #227
V35 Skyline GT's Avatar
6MT Coupe
^Why three OC tests? TSB even before last two revisions would only take one, maybe two depending on the situation. They should've ordered your V2 from your last test results. Three tests was the old method req pre TSB.
Old Jun 10, 2008 | 12:57 PM
  #228
Gcoupe06's Avatar
I don't know, that's what he told me so I'm just going along with it. after all he said, it's guaranteed to be replaced.
Old Jun 10, 2008 | 01:01 PM
  #229
6MT Coupe
Originally Posted by twin001
My the upper and lower collector had a thin layer of oil coated on them. I cleaned it out with some throttle body cleaner.
Hey thanks for confirming that. I'm still throwing around the idea of a catch can for my V2. Haven't decided yet.
Old Jun 10, 2008 | 01:03 PM
  #230
Nasty_Nissan's Avatar
I'm taking my car in for a second time as well and my dealer has also informed me that I'm looking at a new engine after this last check. Hopefully everything goes through smoothly and the new replacement I get doesn't have the same problem.
Old Jun 10, 2008 | 01:04 PM
  #231
6MT Coupe
Yeah...that's all that matters, just that the TSB guidlines would've got your V2 sooner for you.
Old Jun 10, 2008 | 01:14 PM
  #232
6MT Coupe
Mine took two times as well, but that's b/c I requested test to continue after first. They played me on first level reading, so came back second time at qt low = kept my G in sight 100% = no room for games = qualified = call for approval = approved next day by Infiniti = ordered V2 = done deal.
Old Jun 10, 2008 | 01:32 PM
  #233
6MT Coupe
Anyone else notice these things or is it just me?
Originally Posted by ZeeForce
It’s just you!
^ Oh... ... ...
Thanks for the props too ZeeForce and your update.
Sounds like pinging will be a fact of life on these...crap I hate detonation...not good for any engine.
I have some tricks up my sleeve about that condition I was going to do on my original if I didn't qualify for V2, but will now wait untill I know this one has no OC. Already mentioned one...catch can. There's a few more, but will wait to see if mine starts pinging.
Old Jun 10, 2008 | 03:14 PM
  #234
Archangel's Avatar
I wish I had gone through this thread sooner. My car started making noises a few weeks ago. My check engine light was already on because of my high flow cats, so I did think to check the codes at this time. I thought is was the clutch throw out bearing. Replaced the clutch and the noise is still there. I took it to Infiniti and they said the oil was really low even though I replaced the oil 3000 (ish) miles ago. Then I find this TSB thread. So I've got the oil consumption and engine noise which according to the TSB should warrant an engine replacement.
Here's the kicker: I left my Hi-flow cats in place still thinking it was a transmission problem and now they are telling me they won't cover the engine under warranty.
They don't think there is any engine damage right now, but the problem will keep coming back.
Anyone know if I could win a law suit keeping in mind the TSB and the Hi-flow cats?
Old Jun 10, 2008 | 03:24 PM
  #235
6MT Coupe
^ This might help...
http://www.sema.org/Main/SemaOrgHome.aspx?ID=50100
And/or this...
http://en.wikipedia.org/wiki/Magnuson-Moss_Warranty_Act
Some dealers make mods a big deal, while others don't. They have to prove your HFC caused the failure.
It's BS as many 100% stock revups have failed with this known defect.
G/L
-EDIT-
Okay...I'm looking like a PW. Will chime in when I have something to say comcerning my V2...good or bad.
Last edited by V35 Skyline GT; Jun 10, 2008 at 03:32 PM. Reason: Looking like a PW
Old Jun 10, 2008 | 03:25 PM
  #236
twin001's Avatar
You need to push back at the dealership, HFC's will not void your warranty. Call Infiniti Customer Care and talk to them. There is a law called the Magnuson-Moss Act, see link attached. It won't be as easy since your car isn't stock but you can still go through with the OC testing.
Good luck!
http://www.duramax.bizhosting.com/ma...s-warranty.htm
Old Jun 10, 2008 | 03:44 PM
  #237
Archangel's Avatar
Thanks for the replies. Yeah, I'm getting very familiar with the Magnuson-Moss Act and Sema at the moment. I'm waiting for the service adviser to call me back on this subject after I brought up the TSB. If she says they still won't cover it, I'm going to have her get the service manager to explain in writing why the HFC would cause the damage to the motor and consumption of oil.
Old Jun 10, 2008 | 03:53 PM
  #238
shdowflare's Avatar
From what I've been told, Nissan has been burned in the past by faulty cat material somehow making it back up into the engine in older Sentras or Maximas, I think. I really don't see how this is possible, but I knew they'd try just about anything to not warranty a new motor - so I took off everything except my cat-back exhaust - plenum spacer, CAI, headers, and HFC's. And I got the new motor...
I highly recommend anyone going in for a new VQ do the same. While Infiniti doesn't have the "right" to deny your new motor under warranty because of certain aftermarket parts, the road to your new VQ will probably be far less troublesome if you play by their rules to some degree. Just accept that going as close to stock as possible is your best move, and pay a little money to do it. It's a worthwhile investment for a new engine.
Old Jun 11, 2008 | 12:58 AM
  #239
ZeeForce's Avatar
I have some tricks up my sleeve about that condition Already mentioned one...catch can. There's a few more, but will wait to see if mine starts pinging.
I hear ya, have you got 7 Ben Franklins lying around I can borrow.
Old Jun 11, 2008 | 01:36 PM
  #240
6MT Coupe
Haha...uhh...no sorry I don't
You have already rated this thread Rating: Thread Rating: 4 votes, 3.75 average.
