Infiniti Rev-Up Oil Consumption TSB
#662
247 horsepower / 236 lb/ft torque
Completed on a dyno jet. V2 Rev-up motor 2007 G35 coupe 6mt CPO vehicle.
Conditions were hot, 96 degrees, 28 percent humidity, 29.5 pressure
I was expecting 250-260 horsepower and 240-245 lb/ft of torque but I think the conditions were just too hot today because the car also had a ping around 5K and you can see the ping in the results. Let me know if anyone wants to see the printouts and I will post them up.
Thanks
#663
#664
#665
on
You should have tell him you were able to reach the previous owner and thus "found" them. The Infiniti dealer will not care as long as you furnish some type of evidence so they can cover their butts.
#666
![Mad](https://g35driver.com/forums/images/smilies/mad.gif)
#667
#668
hmmm. I just took my 05 rev up engine in. Wasted $50 on an oil change (back to dino) that took them 3 hours as I waited. On the receipt they made a comment that I have an aftermarket oil filter. Looks like they are already trying to biuld their case to reject me.
quick question for those in the know. I don't drive my care much but since I bought it used, I have done all the oil changes myself with synthetic oil. I have kept records not receipts. I have been changing my oil out at the milage interval.....not the time interval. Most of the time I go 4 to 6 months on synthetic oil before I change it. Any idea how infiniti handles that. Have I allready screwed myself if my engine is shot?
thanks
thanks
#669
thanks
thanks
#670
All,
I am looking at a used 05 sedan with the 6MT (rev-up motor). Going to have the [Nissan] dealer selling it check what's in the little owner's booklet in terms of service history. The car has 35k on the odometer.
From what I gather in the TSB, the motor can still be replaced under warranty if there's no oil change history? Seems like the process takes longer because they will monitor it, but you'd still be covered.
Right?
Last thing I want to do is buy the car, find out it drinks oil, and be stuck footing a $6000 bill for a new motor.
Right?
#671
on
All,
Right?
Right?
Depending on the dealership you will have either more or less difficulty getting this done on their dime. I was fortunate to find a dealer (not my local dealer, but rather one recommended by a friend) that replaced mine (which BTW was a rare non-revup oul burning motor) after I showed them a maintenance log up to 53K miles (I bought the car at 17K). The log showed all oil changes done at/around the factory recommended intervals, and all other work I'd had done (30Km 45K, 60K, etc). I made sure I had all the receipts. I was able to "find" those which I had misplaced or were missing altogether.
![Big Grin](https://g35driver.com/forums/images/smilies/biggrin.gif)
And regarding the $6000 that's only for the motor itself, and doesn't include any additional, supporting parts or labor. I can show you guys my invoice to see what the replacement really costs. I think it's more like 8-10K.
Good luck. Since getting my engine replaced a year ago (22K miles later), I'm only burning about 3-4 mm per 3000 miles. That's within the normal oil consumption range. It's rock solid now, and I get the oil changed with synthetic blend (per the dealer's recommendation) no more than every 3K miles, no exceptions this time! I know I'm not getting another motor and need to take very good care of this one. So far it's paid off.
![Driving](https://g35driver.com/forums/images/smilies/driving.gif)
#672
That assumes the previous owner had the car serviced at Infiniti. I can tell you that my father only took his car to the dealership for big stuff. Oil changes & brakes...he had it done at Jiffy Lube or Midas or whatever. The car was maintained well, but the dealer has no knowledge of it...he saved his receipts though.
So a rev-up motor with no oil change history is a potential nightmare, and wouldn't be worth the risk...right? From what I gather there's no easy way to tell if the motor is burning oil just from looking. Some say that an oily tailpipe is an indicator.
#673
r u losing oil? If so how much? If its less than 1 quart and oil change then you won't be getting the motor replaced. You are supposed to change your oil at either the mileage or the date, WHICHEVER COMES FIRST. So you are not changing your oil per manufacturer specifications because you are waiting 4 months minimum to change your oil. I would stick with an OEM oil filter if you are losing a lot of oil. I don't think they are building a case against you, but the oil filter size, shape, and aftermarket oil filter's filtering abilities can all have an adverse effect on the oil. If you are having oil consumption issues and are still under warranty, sticking with OEM oil filters and OEM recommended oil type is going to make your life a lot easier in dealing with a dealership about a oil consumption issue. I usually change my own oil in my personal vehicles. But when I just bought the car, I had them do the first 2 oil changes because the previous owner complained about oil consumption before I bought the car. I did not want to give the dealership any reason to deny my oil consumption claim. My dealership changes my oil for $40. And that was high mileage full synthetic at the last oil change. Maybe some dealerships need the business more than others, hence the reason my oil changes are cheaper.
Hey bud thanks for some insight. I actually looked it up and I fall under the Schedule 2 conditions therefore requiring me to change my oil every 6 months or 7,500 miles. Hmmmm. I have been burning between 1 and 2 quarts between oil changes. I guess my next step is to try to track down the previous owner or dealership that my car was serviced at before I bought it. Is there a data base that my local dealership can look at to see if it was maintaned at another infiniti/nissan dealer? Or do I need to start calling the chicago dealers (thats where it was originally bought) and giving them my VIN # to look up. Thanks.
![Dunno](https://g35driver.com/forums/images/smilies/dunno.gif)
#675
on
That's all I was really saying. We all know that many people don't get their simple, routine maintenance done at the dealerships, but getting their service history report is a good place to start since that's what Infiniti already knows about your car in their system. Thus, you'll get a baseline from which you can assemble your supplemental service history information. With that baseline, you can "figure out" how to locate what they're missing so you can fill in the gaps for them. That will get you on the road to a new engine if you need it.
