Ecu tuning 2002/2003 g35sedan (very technical)
Old Aug 1, 2018 | 08:56 AM
  #316
Eric@TCGMiami's Avatar
^ thats the only chance... just lol im not trying to go that deep.... emailed nisformance and haltech lets see what happens.
Old Dec 12, 2018 | 01:37 AM
  #317
G35_Sedan_TT's Avatar
G35 Sedan with APS Twin Turbo Kit
Hey did you ever find a solution for your early 2003 G35 ECU? I'm currently in the same boat...I have an APS twin turbo set up and trying to get my ECU tuned with adjustable profiles (i.e. ECO mode, High boost mode, etc.).
My local dyno tuning shop tried getting my ECU flashed through UpRev, but they couldn't do it for my early 2003 G35 ECU.
Old Dec 20, 2019 | 09:36 AM
  #318
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
The 03' grey connector and early 04' black connector are narrow band primary O2 ECU's. They can be tuned with some freeware crap but I wouldn't spend the time tuning them since they are old school. Convert to a 04.5' up harness and ecu that has wideband targeting and use UpRev for best results. You will have a lot better tune and be happy that you did.
Old Nov 8, 2021 | 02:56 PM
  #319
Dipi's Avatar
Blue
Originally Posted by Abouz
Pulling up the old thread to see if anyone got any answers for this?!?! I read through the whole thing and it seems no one pulled the trigger on swapping the whole engine harness and ecu?!?!
Well I went ahead and stupidly did that to see if it would work.
I have swapped the engine, engine harness, ecu, and transmission from an 04 350z....
Everything seemed to hook up perfectly aside from the oil sensor and 02 which I had swapped as well but aside from that practically flawless fit. (Note trans plugs where different but I swapped the trans so it fits).
Here is the thing:
It turns over but won't start.
Looks to be the security system but when I got someone to try and program the key it wouldn't read the ecu.
One weird thing is that the radiator fans don't shut off unless I remove the battery. (Could this mean even though everything hooks up the wiring is different?)
Would I have to change the cluster?
Also if I was to succeed what features would be missing since the original ecu controls more features other than engine?
Has anyone succeeded with this and just didn't speak up?? If so any help is appreciated.
This normally means the Ecu is fried, do u know if it worked before?
Old Mar 9, 2023 | 10:10 AM
  #320
Javi2valid's Avatar
its the premium
Question would this new haltech work on my g35 sedan 6mt?
heres the link do the product:
https://www.haltech.com/product/ht-0...o-plug-in-ecu/
Old Mar 10, 2023 | 12:28 PM
  #321
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yeah but what do you need a standalone for? Unless you need it for boost applications where you need extra safeties like boost cut and whatnot then you're better off with an Uprev tune. Not to mention it's only about 1/4 the cost and you get to keep all your other car stuff intact with no dash lights.
Old Mar 10, 2023 | 12:34 PM
  #322
Javi2valid's Avatar
its the premium
yeah I’ll be tuning it myself and I’ll be using twin turbos
Old Mar 10, 2023 | 01:23 PM
  #323
cleric670's Avatar
BANNED!!!
Ahh, check out which ECM you have in this thread (it's the one in the middle with the black housing). Make sure it's harness/plug is the same in the Haltech video.
https://g35driver.com/forums/g35-cou...ml#post7170856
Old Mar 10, 2023 | 01:34 PM
  #324
Javi2valid's Avatar
its the premium
this car was bought new off the lot so maybe right?
Old Mar 10, 2023 | 09:15 PM
  #325
cleric670's Avatar
BANNED!!!
You'll have to just look, it's in the passenger footwell.
Old Mar 11, 2023 | 11:35 AM
  #326
seymore4's Avatar
m56
It takes literally 5 minutes to look and see which ECU you have. If you have the one with the big green checkmark next to it, PM me and get an Uprev tuner kit (I can save you some money). Gives you full control over everything and there are thousands of boosted VQs tuned with Uprev.
Old Jun 3, 2023 | 04:40 PM
  #327
Javi2valid's Avatar
its the premium
Lightbulb i have the older model ecu that uprev doesn't support
couldn't i just swap in a 2003 350z ecu in it?
Old Jun 3, 2023 | 04:47 PM
  #328
cleric670's Avatar
BANNED!!!
Yes, you can repin the chassis harness to the newer harness style and use a newer ECM, you will need to have it programmed and paired to the BCM and NATS as well before the car will start.
This option is a lot more viable now that there are plenty of donor cars sitting in wrecking yards.
FSM has the ECM pinout, section EC - Engine Controls
Old Jun 3, 2023 | 05:11 PM
  #329
Javi2valid's Avatar
its the premium
can you send me the link?
Old Jun 4, 2023 | 10:06 AM
  #330
cleric670's Avatar
BANNED!!!
https://www.nicoclub.com/infiniti-se...ls#g35_g37_q40
