DIY: Installing Sport paddles
Old Feb 19, 2009 | 07:20 PM
  #226
ced357's Avatar
How do I properly disconnect the car battery? Someone on here said just remove the + side. Then I read that you just need to remove the - side and leave the positive side alone.
Old Feb 19, 2009 | 07:22 PM
  #227
AesonVirus's Avatar
If you're that much in doubt.. remove both!
Old Feb 19, 2009 | 10:42 PM
  #228
AlterZgo's Avatar
Either will do it.
Old Feb 20, 2009 | 06:35 PM
  #229
G35_OH's Avatar
The Infiniti Service Manual always refers to disconnecting the cable from the negative terminal when it wants you to removing battery power. In reality, removing the cable from either terminal will remove battery power since it breaks the serial circuit.
Disconnecting the negative cable is a little safer than the positive cable. Why? Because the positive terminal is connected to a limited number of discrete points (i.e. to the radio, headlights, etc) while the negative terminal is connected to the frame of the vehicle. What that means is that if you disconnect the positive terminal, you merely need to touch the frame of the car (or anything connected to the frame) and the positive terminal of the battery to complete the electrical circuit and give yourself one heck of a shock. Whereas if you disconnect the negative terminal, then you must be touching one of those discrete points (say positive terminal on the radio) and the negative terminal of the battery to complete the electrical circuit and shock yourself - clearly this is much harder to do.
Old Feb 20, 2009 | 07:15 PM
  #230
ced357's Avatar
Thanks, I really appreciate it. I’ve never worked on a car before and would like to give this mod a try. I’m just a little cautious. Especially with the airbag. It makes me nervous.
  #231
mishmosh's Avatar
Originally Posted by G35_OH
The Infiniti Service Manual always refers to disconnecting the cable from the negative terminal when it wants you to removing battery power. In reality, removing the cable from either terminal will remove battery power since it breaks the serial circuit..
THANKS!!! I've always wondered about this and your explanation makes perfect sense!
Old Feb 20, 2009 | 07:19 PM
  #232
AesonVirus's Avatar
Disconnect the battery and follow the instructions very carefully and you will be fine.
If you get to the wiring harnesses and can't get them apart, stop and re-read the instructions again. Don't lose patience and start tugging... you'll end up with more trouble than you want.
There's a clear explanation on how those airbag clips come apart. Just make sure you understand all the steps before you start and you'll be fine.
Plus, if you need help, drop your questions right here. Someone is always online at one time or another so help is always a minute or two away.
Good luck.
Old Feb 20, 2009 | 08:40 PM
  #233
ced357's Avatar
Sounds great, I really appreciate it. I will be doing this next week and if I run into any issues I'll be posting in a second. I don't want to mess this up. Thanks again.
Old Feb 26, 2009 | 06:13 PM
  #234
ced357's Avatar
Took me awhile to find the correct tools, but once found, the install was a breeze. Thanks for the help
Old Feb 26, 2009 | 09:11 PM
  #235
Wes_888's Avatar
It was that easy for u? NICE.... good job =)
Old Feb 26, 2009 | 09:17 PM
  #236
AesonVirus's Avatar
See that CF Boy? The new guy did it... it was a breeze.
Feeling tempted yet?
Old Feb 26, 2009 | 10:24 PM
  #237
Wes_888's Avatar
No can do kind sir!
I got door panels to CF this weekend!!! if I manage to take apart the door panels and return them on properly without destroying anything, maybe that will give me the confidence to attempt the paddle shifters :P
Old Feb 26, 2009 | 10:27 PM
  #238
dev1983's Avatar
sorry, I didnt feel like reading thru 11 pages...is it possible to put paddle shifters on an 03 coupe?
Old Feb 26, 2009 | 10:32 PM
  #239
EWG35's Avatar
One other reason to remove the negative terminal clamp is the hot side (+) can touch a metal ground and cause a big spark. I've done it many times.
Old Feb 26, 2009 | 11:28 PM
  #240
earth0's Avatar
I put it myself since first week i've got the G.It's ok btw.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
