DIY: Clean your throttle bodies
Rating: Thread Rating: 2 votes, 4.50 average.
Old Mar 21, 2010 | 11:30 AM
  #76
BuckeyeInMI's Avatar
Originally Posted by kool_yaar
You wont need to do the relearn procedure as long as you do NOT disconnect the harness on TB.
Technically, you're right, but you really can't clean it completely without removing it from the car. I don't see the point in doing a half-azzed job on it when it's so simple to do the idle position re-learn.
Old Mar 21, 2010 | 01:44 PM
  #77
Defratos's Avatar
You're Despicable
you can clean it pretty well with the connections plugged in, hard to do better
Old Mar 21, 2010 | 01:50 PM
  #78
kool_yaar's Avatar
@buckeye, you can clean them to perfection while installed on the car as outlined in the DIY if you take your time and maintain patience there is MORE than enough space to do this.
Old Mar 21, 2010 | 02:00 PM
  #79
Q8y_drifter's Avatar
A half azzed job would be to clean the TB without removing the 4 allen bolts and cleaning from the back (no offense Defratos )
However, as long as you take off the TB then you have all the space you need to clean the entire thing as well as the plenum itself. We're not trying to polish the thing, just taking off the carbon build up.
Old Mar 21, 2010 | 02:26 PM
  #80
Defratos's Avatar
You're Despicable
^ Hey!!! I took mine off
Old Mar 21, 2010 | 02:29 PM
  #81
JOKER's Avatar
CLUB MODERATOR
I've done TB and MAF cleaning this weekend and now I got check engine light.
I'm gonna blame it on a TB gasket and get a new one.
Car drives fine tho and accelerates fine.........idles a little high tho (1.5k)
Old Mar 21, 2010 | 02:33 PM
  #82
I'm just not sure what the advantage is of doing it that way. Yes, you don't have to do the idle re-learn, but it's so simple to do, I would think the extra hassle of trying to clean it while it's still attached just wouldn't be worth it. It's far easier to get it perfectly clean if you remove it completely, and the idle re-learn takes almost no time at all. I know that's how I'll do it whenever I clean it.
Old Mar 21, 2010 | 02:35 PM
  #83
That will go away fairly quickly, maybe a few days. It's still learning. My cars have always had a few days of high idle after a good TB cleaning.
  #84
Defratos's Avatar
You're Despicable
just out of curiosity how did you go about cleaning your MAF? because it's pretty sensitive
Old Mar 21, 2010 | 03:42 PM
  #85
G35s-Q8's Avatar
+1 on that, as i said before, take the car for a spin, and do some WOT, and it'll go.
Old Mar 21, 2010 | 03:44 PM
  #86
JOKER's Avatar
CLUB MODERATOR
Took it off and sprayed the fvck out of it.
let it dry, and put it back on.
Old Mar 21, 2010 | 03:59 PM
  #87
Defratos's Avatar
You're Despicable
lol what exactly did you use to spray the fvck out of it?
Old Mar 21, 2010 | 05:03 PM
  #88
There's Mass Airflow Sensor spray out there. I have some made by CRC. http://www.crcindustries.com/auto/co....aspx?PN=05110 Most decent auto parts stores will have something.
Old Mar 21, 2010 | 07:20 PM
  #89
JOKER's Avatar
CLUB MODERATOR
^that's what I used
Old Mar 22, 2010 | 05:40 AM
  #90
Defratos's Avatar
You're Despicable
Ok in that case I doubt you've damaged it, I thought you might have used WD-40 or something
You have already rated this thread Rating: Thread Rating: 2 votes, 4.50 average.
