New Stillen Dual intake for 07 350Z
Originally Posted by logik05se
the sound of an intake is worth every penny. I miss my coupe because of the Injen.
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
And for those talking about the price, remember that you're getting 2 intakes... most decent intakes when they were released were about $200 a pop anyway, so this is about even.
sometimes a flat housing is better as it causes turbulence that eventually leads to mixing, which is good for MAF sensors (which we have). I've seen several cases where a pod filter mounted on a velocity stack actually ruined an idle and caused fueling problems. THat's not to say pod filters are "bad" but the MAF sensor needs to be located and designed to handle the flow characterstics of a velocity stack. Factory MAF's are designed for the intakes that the car comes with, not for anything else. Start changing variables and undesirable effects are possible.
Originally Posted by viguera
The sound should be nice... but the question is whether or not it would hinder performance over the stock intakes. The stock design is fantastic and I wouldn't want to lose hp for better sound... ![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
Originally Posted by Altersys
if you start messing with runner diameter without working on engine tuning you can lose a lot of output.
I'm of the opinion that messing with factory bolt-on parts without any interest in tuning is an act of mental masturbation (and a waste of money).
![Bowdown](https://g35driver.com/forums/images/smilies/bowdown.gif)
#30
