Nissan Power Pup Bullydog - First Impressions
  #736
Old 09-14-2009, 11:35 AM
Scooby24's Avatar
geeze, you all are getting raped on the dyno costs. If anyone wants to go on a faith based system and send me your bullydog for testing, I can check into a cost for 2 before, 2 after runs at the shop down the road from me and surely do it cheaper than you guys are being quoted.
  #737
Old 09-14-2009, 02:14 PM
AesonVirus's Avatar
Has anyone confirmed that the tune needs to be removed before it can be installed anywhere else?
  #738
Old 09-14-2009, 02:16 PM
Scooby24's Avatar
If it's anything like the Cobb AP, it would marry itself to the ECU and wouldn't work until you unmarry it....but apples to oranges.
  #739
Old 09-14-2009, 03:14 PM
Scooby24's Avatar
I just talked to the shop owner and he said he'd do 2 before and 2 after pulls for 50 bucks so if someone wants to see the results for that cost and trusts me with their unit, I can get this done.
  #740
Old 09-14-2009, 04:23 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I'm sure that's the case.
The other issue is getting a file to match Scooby's ECU
  #741
Old 09-14-2009, 07:39 PM
AesonVirus's Avatar
I thought about that too. If I send mine out, it's coming back with a program on it that may not be compatible.
Question now is, can I go backwards in updates (downgrade)?
  #742
Old 09-14-2009, 10:19 PM
InTgr8r's Avatar
I think the upgrade files include all ECU to that point,
....but you should be able to just reload the file they sent you.
  #743
Old 09-14-2009, 10:45 PM
Q8y_drifter's Avatar
if his file does not work just contact BD for the correct one.
  #744
Old 09-19-2009, 01:46 AM
LakeShore_Slate's Avatar
has anyone found a dyno besdies the one that couldnt be printed? from like page 7 or 8? i dont know if i want to buy, but i probably will.
  #745
Old 09-19-2009, 02:05 AM
Originally Posted by kendroz
The first run was full stock on the car, no HFC's.no KN filters and No h-pipe.
The second run was with HFC's,KN filters, H-pipe and Bullydog. What I saw on the dyno was that the BD makes more power under the curve and the +2 deg makes it more aggressive but the same peak power (268) at lower rpms.
At WOT your can feel more power after 3800 rpms and up.
I cannot scan the dyno because the printer on the shop was not working.
I still running the stock resonators and mufflers and I notice that they struggle getting the air out. I regret that I sold my FI catback because I feel that this new setup it more suitable for it.
The thing with my car now is on startup. When your press the start button the car start and then shuts down. I believe this is because a lot of fuel and the HFC's. At some times I got the CEL with P0420 and P0430 and I clear those with the BD. I called Tony of FI and he talks about a modification on the HFC's.
Those are my impressions and comments.
"At some times I got the CEL with P0420 and P0430 and I clear those with the BD."
What language is that btw?
  #746
Old 09-19-2009, 02:28 AM
pfarmer's Avatar
CEL - check engine light.
I would have to look up the codes but maybe 02. He clears the codes using the Bully Dog.
  #747
Old 09-19-2009, 03:46 PM
oh ok, I see.
  #748
Old 09-19-2009, 06:41 PM
albaugh81's Avatar
Jack090 could you send that update to me if you still have it?
  #749
Old 09-20-2009, 07:09 PM
jack090's Avatar
Sent
  #750
Old 09-22-2009, 05:20 PM
3volved's Avatar
I'm very much contemplating this for my 6MT. If I do decide to get it, I'll be taking a baseline and post installation dyno as I'm interested in the bottom line numbers as well.
Quick Reply: Nissan Power Pup Bullydog - First Impressions
