I'm NOT happy with my new intakes !!
Old Dec 9, 2009 | 08:23 PM
nghiars's Avatar
silnecers?
Old Dec 9, 2009 | 08:26 PM
Glover997's Avatar
Originally Posted by jibberjabbers
The stock air intake is already an enclosed system that takes in cold air. All you have to do is switch to a high flow filter. Or maybe grab a 350z intake tube.
Most aftermarket intakes offer a high flow filters, but its grabbing in hot air at the same time.
And the testings they do is laughable. LOL. They have the car running on a dyno with the hood wide open and a big fan blowing at it. Who here drives with their hood wide open?
along with a big fan in front of us ?
Old Dec 9, 2009 | 08:34 PM
Glover997's Avatar
Originally Posted by nghiars
silnecers?
silencers
Old Dec 10, 2009 | 04:05 AM
Bahg35's Avatar
Originally Posted by E-Ticket Ride
That small of a difference could be attibuted to human error. Get a more accurate way to measure it and try it again.
+1
You'll need a more accurate way to measure that bro.
Do you guys have a drag strip down in oman? A run down the 1/4 mile strip will be more accurate than your stop watch mate.
Old Dec 10, 2009 | 08:38 AM
Glover997's Avatar
Nope . . we don't have !
supppose that the stopwatch is not accurated, is not it the same watch i was usin before i install the intake ?! my point is . . results shud be the same, regardless of the drag mile's measurement .
Old Dec 10, 2009 | 08:41 AM
Glover997's Avatar
again (2) . . can i install my stock intakes back without the resonators ?
Old Dec 10, 2009 | 10:22 AM
Austin713's Avatar
i dont see why not?
Old Dec 10, 2009 | 03:38 PM
soundmike's Avatar
Yes you can.
I'm curious though, what were the relative humidities when you tested b/a intake?
Also, i'm with the other posters, try to find a timing tree or something more accurate than a stopwatch. 0.5s is easy to fumble, although it doesn't take into account your 3 second difference on longer runs.
Old Dec 10, 2009 | 04:16 PM
B L U E S L A T E's Avatar
Honda Accord
Do a ECU reset and let the car relearn your driving style.
Old Dec 10, 2009 | 04:17 PM
Honda Accord
Yes, and it's not gonna do crap. I've done it so I know.
Old Dec 10, 2009 | 08:32 PM
Glover997's Avatar
well . . pullin the negative terminal while installin the same along with the BB grounding, is an ECU resest by itself !
Good to know that . . thank you very much .
Old Dec 10, 2009 | 08:45 PM
Glover997's Avatar
Originally Posted by soundmike
Yes you can.
good !
well . . it's a stable dry weather here, bet there is no difference at all !
ok . . i'll try to do that !!
Red is self explained .
Old Dec 12, 2009 | 05:50 PM
IvoryPearl07G's Avatar
yes you can run without the resonator/silencers. it was the first thing i tinkered with on this car a couple of years ago.
Also, if those intakes are a short ram style, i believe you when you said they slowed the car down. I used to have fujita short rams on my car. i saw a couple of tenths and two mph lost in the 1/4 miles. i sold them and picked up injen true cold air intakes and saw all the power/accel come back plus some. put the stock intakes back in and you will get your acceleration numbers back.
Old Dec 12, 2009 | 07:20 PM
bat6wc's Avatar
i suggest you do 3 "runs" with R2Cs, then 3 "runs" directly after with the stock intakes. Average the 3 runs for each intake set up. even though its not the most accurate way measure, you can still use the stopwatch if you use the same stopwatch for all 6 runs.
Old Dec 15, 2009 | 04:04 PM
  #30
Glover997's Avatar
thank you guys for passing by .. i'll do what u've suggested
