Cold Air vs Short Ram
Old May 27, 2010 | 11:25 AM
  #31
Defratos's Avatar
You're Despicable
Originally Posted by AesonVirus
I'm with Daffy Duck
I didn't notice too much in terms of loses and I also didn't notice too much in terms of gains, but the car does seem to get through the higher RPMs quicker and the noise.... I just love the noise
Old May 27, 2010 | 06:25 PM
  #32
KC23's Avatar
It's all relative. If you can aford to play around experimenting with bolt ons that is one thing, but if money is tight non-of this stuff is necessary.
Old May 27, 2010 | 06:31 PM
  #33
AesonVirus's Avatar
I agree that the intake is a waste of money if you are looking for purely performance gains, but I argue that exhausts are a waste of money.
My car had immediate change for the better once the FI system was on.
Old May 28, 2010 | 10:17 AM
  #34
Austin713's Avatar
+1000
my FI is my #1 reccomended mod... completely changes the car for the better in every way. Looks Performance and sound.
Old Jun 17, 2010 | 09:24 PM
  #35
2GoRNot2G's Avatar
I agree completely. I actually gained more HP from my K&N intake then I did from my exhaust (sans the HFC's), and the exhaust ended up costing 3 times as much.
I've actually had two different aftermarket intakes and currently have the Takeda in the car now. When I installed the K&N system I did a before an after dyno the same day and ended up with 4 - 6 HP gain throughout the midrange and a max gain of 7 HP and 9 Ft-Lb of Torque. I've posted several threads on here with driving impressions an dyno charts, just do a quick search if your interested.
The advantages of a CAI (Ingen, Stillen 3, etc) over a short ram (like the K&N & Takeda) is that they actually pull cool air from outside the engine bay. You will more than likely get higher peak gains with a CAI, but your gains in the midrange will be less than a short ram intake due to the long tube design. The short tube intakes tend to give you more mid range power but can suck hot air which will sacrifice peak power. I actually built custom cold air boxes for my intake to help remedy this.
Of course, as has been mentioned here, I feel that the biggest advantage of an aftermarket intake (either CAI or Short Ram) on our cars is the beautiful soundtrack it makes at WOT. I've fallen in love with the new engine sound with the aftermarket intake and could never go back to my stock intake... even my wife loves the sound!
Old Jun 18, 2010 | 02:20 AM
  #36
kendroz's Avatar
I did install stillen gen 1, lot of sound (yes!) not much power.
Put stock boxes back with K&N dropin filters, better than oem.
Put stock boxes with HKS dropin filters, not much different.
Iám in the middle of buying cobb maf hose to test.
Which short ram is better than stock boxes?
K&N, Stillen Gen2 or R2C?
Current mods: K&N dropins, BB ground kit, FI HFCs,custom exhaust, BullyDog.
277 whp, 244 lb/ft
KruZZe
Feb 27, 2023 05:04 PM
BradMD_96
Oct 6, 2015 09:31 AM
Jcruzg35
Sep 26, 2015 04:47 PM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
