Why does my car sound like a Harley!!!
Old Sep 22, 2011 | 11:10 AM
Defratos's Avatar
You're Despicable
Unhappy Why does my car sound like a Harley!!!
Soo yesterday I'm driving back home, doing maybe 30-40km/h and all of a sudden I hear a load sound like a Harley just pulled up next to me.
I look around trying to see where the noise is coming from and then realise it's my car , drove back home doing 5mp/h so I don't wake up the whole neighbourhood (and even that didn't help it was load as F*%k)
So I look around and the noise seems to be coming from where the cats and engine manifolds are, I didn't feel any sort of jerks or anything coming loose when the noise happened so I'm confused as to what it could be.
The only thing I can think of is either the cats have come loose (they seem solid but I need to get underneath to have a proper look)
Or something went bad with the manifolds.
Can anyone take a guess on what the problem could be? Has anyone experienced something like this before?
One more thing, so far there's no engine warning lights.
Old Sep 22, 2011 | 11:22 AM
MotF Bane's Avatar
Your location says sand dune, so I assume you are somewhere that rust isn't a major concern, correct?
Old Sep 22, 2011 | 11:24 AM
kool_yaar's Avatar
if i remember right you had your berk CATs die on you a while back, its probable that the new cats core have also lost their place/dismantled thus the loud noise which is common when the core gets loose in the HFC.
Else it could always be something loose in the exhaust setup
Old Sep 22, 2011 | 12:09 PM
Defratos's Avatar
You're Despicable
Well I'm in Jeddah, Saudi Arabia and it's a located by the red sea so rust is a big issue here but if it was rust it'll be progressively getting loader, the noise that I got came on instantly
Yeah I changed my Berks to Invidia but it can't be the core because it's WAY TOO load, honestly the noise sacres me....(I'm trying to upload a vid of the noise.)
I'm 100% sure it's not the core that's come loose, it's seems to be somewhere in the exhaust setup but what would make the loudest noise? I'm thinking manifolds
Old Sep 22, 2011 | 12:14 PM
vqsmile's Avatar
This almost sounds like you've got open headers now. I'd look for a snapped bolt or blown gasket in and around the manifolds. Maybe you've got a pipe that only bolted on one side and is gaping open a bit.
Old Sep 22, 2011 | 12:18 PM
Defratos's Avatar
You're Despicable
^ Sounds like a possibility
Here's the vid:
http://smg.photobucket.com/albums/v2...t=f6011c9a.mp4
It actually sounds loader in real life, I didn't want to keep the car running too long because it's noisy
Old Sep 24, 2011 | 01:23 PM
Defratos's Avatar
You're Despicable
Problem found --> https://g35driver.com/forums/v36-eng...luck-cats.html
Old Sep 28, 2011 | 04:57 PM
djfarhan's Avatar
mine does cuz i got the R2Cs
Old Sep 28, 2011 | 06:12 PM
GAU-8's Avatar
If you don't find any loose hardware or gaps in your seals at the joints, look at the flex pipes in the Y-pipe. Those can blow out too. Unlikely, but it happens.
Old Sep 28, 2011 | 06:13 PM
SxExCx's Avatar
Because Racecar!
Old Sep 28, 2011 | 07:58 PM
kool_yaar's Avatar
Originally Posted by Defratos
Old Sep 28, 2011 | 09:10 PM
Project's Avatar
^^^lol was going to point that at til i got to the bottom
Old Sep 28, 2011 | 09:27 PM
GAU-8's Avatar
Ah, gotcha. Didn't realize there was two threads for the same issue.
chinee
Jun 10, 2024 07:48 PM
TWASkyliner
Feb 8, 2020 08:00 PM
mjfenix
Aug 17, 2017 05:49 AM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
BlackGee35
Jul 21, 2015 07:24 PM
