Weird issue when accelerating
Old May 23, 2012 | 08:03 AM
Frankenstein's Avatar
BTW my car has the metallic rattle issue on hard accel too. It's been doing it since I picked it up 2 years ago with 36k on the clock, but it hasn't gotten any worse so I'm not worrying about it.
Old May 23, 2012 | 10:01 AM
Defratos's Avatar
You're Despicable
Well my metallic rattle issues is not due to the brake fluid or the engine signs I was getting.
Ever since I changed my pads I no longer get the warning lights on my dash on WOT.
The metallic rattle issue is still there and ONLY comes to play at 3,000 rpms (any gear)
Other than 3k I never heard a thing. I'm slowly trying to make the sound worse by holding my gears at 3k so I can find where the noise is coming from. I'm hoping it something loose which will eventually be obvious to see.
I'm 100% sure it's something to do with my exhaust or the heat wraps I've installed. If you know my history with my car I've gone through a bit in relation to my exhaust and HFCs so It's most likely down to something in the exhaust system.
Here's a brief summary of the issues I've gone through:
https://g35driver.com/forums/v36-eng...luck-cats.html
https://g35driver.com/forums/media-s...years-old.html
Brings back good memories
Old May 23, 2012 | 06:48 PM
kristof's Avatar
My 07 g35x has the same rattle/rasp noise your talking about and it has all OEM exhaust on it with 84k miles on it. I was actually gonna take it in next week to have it checked as I thought it was a problem with the mufflers. I took those off and drove it around and the sound was still there. I'm guessing it's something closer to the front of the car.
Old May 24, 2012 | 03:01 AM
Defratos's Avatar
You're Despicable
^ Yeah but the only difference is my exhaust is in no way OEM, Its an Invidia exhaust.
Old May 24, 2012 | 07:39 AM
kristof's Avatar
That's what I'm getting at, it may be something other than the exhaust it self? Maybe a heat shield that's attached to the body instead of the piping.
Old May 24, 2012 | 10:14 AM
Defratos's Avatar
You're Despicable
Do you hear your rattle noise only at a certain rpm? and in all gears?
if so then which rpm?
Old May 24, 2012 | 07:11 PM
kristof's Avatar
3k and above. Any gear.
Old May 25, 2012 | 05:13 AM
Defratos's Avatar
You're Despicable
how long have you hard the rattle? because mine has only recently started acting up (maybe 2 months)
Old May 25, 2012 | 07:18 AM
kristof's Avatar
I bought the car in January and ive put 9,000 miles on it since then and its done it since purchase.
Old May 28, 2012 | 06:31 AM
Defratos's Avatar
You're Despicable
Well finally foud the problem of my rattling noise.
Yesterday the rattling got really bad, so today morning I went to the closest garage to look under the car and found that next to my X-pipe one of the welds had come loose which was causing the rattling noise.
Had Ronaldo weld it back up
Old Jul 16, 2012 | 10:40 PM
kristof's Avatar
Damn. I never seen the update to where you found the issue for that rattle sound. Ill have to get my exhaust checked over. I also found a thin, almost feels like tin shield that the exhaust runs under near the back of my car that makes a lot of rattling noise if you just touch it. I was thinking it may have been that but not I'm gonna get my exhaust piping looked over for what you found.
Dat Kid
Nov 23, 2015 11:18 AM
leo38cheng
Nov 12, 2015 06:49 PM
MsFitFern
Sep 7, 2015 02:45 AM
MyfistYourFace
Aug 8, 2015 11:58 AM
joedaddy1
Jul 28, 2015 02:58 PM
