Transmission fluid change interval
Received 2,463 Likes
on
Coupe 6MT Premium RAS
Anyone else have a hard 2-3 upshift when in manual shift mode?
No clue when the fluid was last drained/replaced, thought it was good for 100K miles. Will need to do it soon, which fluid is recommended and any cheap links where to order it?
edit:
2007 G35x Auto
edit:
2007 G35x Auto
on
on
There's a huge difference between "meets factory specifications" and "factory fluid". The exact same difference applies to to all the bulk produced garbage replacement parts that "meet OEM specification" but only have a fraction of the lifespan the actual "oem part" gets.
I would never use anything other than genuine Nissan fluid in one of these AT's there are FAR too many cases documented on this and other forums where using other brands of fluid causes problems.
Same reason I would never use any cam or crank sensor other than the genuine Nissan ones even tho the aftermarket one's are all built to OEM spec...
on
on
Mike@CZP
Engine-Vendor
766
02-15-2018 04:57 PM
AlexxRyzhkov
08-22-2016 05:42 PM
Karran Dhanroop
08-18-2016 03:00 PM
