How to change interior light bulbs in doors?
Old Jun 6, 2007 | 11:03 PM
  #61
kenasaki's Avatar
thanks, that helped me alot. i was gonna order some festoon bulbs.
so its all the same for the 05-07 sedans?
Old Feb 12, 2011 | 10:31 AM
  #62
PJStyles's Avatar
I've noticed that some of these LEDs are now available in different degrees ie: 32 degrees or 90 degrees. Which one am I looking for here? Any suggestions?
Thanks
PJStyles
Originally Posted by psymonG35
for the Sedan all the interior bulbs and the license plate are all wedge bulbs 194/168 type.
I have replaced the bulbs in 4 G35 Sedans - all of us at work really like the glow of the LED as opposed to the incandescent yellow.
Here is what I did to replace all of them for LED in my G - (the others went all white - I like the blue in the door)
2 x WLED 6-LED bulb for Door (Blue)
2 x WLED 4-LED bulb for License Plate (White)
3 x WLED 4-LED bulb for Rear Reading Lights (White)
2 x WLED 5-LED Wide Angle LED bulb for Map Lights and Trunk (White)
The reverse Lights I haven't done yet but if you look in your owner's manual it has the bulb type there
Old Feb 12, 2011 | 07:13 PM
  #63
Mike75's Avatar
Thanks
PJStyles
I bought all those exact bulbs.
As far as 32 or 90 degree (beam width?) I would think wider is better.
Unless u want a more focused light dispersion go w/the bigger #.
mike730
Jan 12, 2018 04:25 PM
mjfenix
Aug 17, 2017 05:49 AM
ClwMike
Jul 23, 2015 12:55 PM
Jadenkid22
Jul 14, 2015 12:33 AM
