Stillen's Rear Camber Adjusters
Re: Stillen's Rear Camber Adjusters
I heard someone on the 350Z forum had his stock rear arm bent a certain way so that it will be in spec. The arm is already bent and the alignment shop just either straighten or bent it out a bit more to put it into perfect camber settings for the rear.
- Don't argue with idiots. They will bring you down to their level and beat you with experience.=P-
Have you seen any uneven wear yet Wreck?
<hr></blockquote>
I have about 4000K on my tires I think. The tires still looks new. Tire wear is my number one concern. Second, is I think if the camber was correct it would fill in gap and make my rims look wider.
G35C 6MT / AMG E55
<hr></blockquote>
G35C 6MT / AMG E55
<hr></blockquote>
That would be definately the economical way out to fixing the camber. I guess that is something to think about.
G35C 6MT / AMG E55
<hr></blockquote>
G35C 6MT / AMG E55
on
The site is www.MY350z.com
The member's name is Lsdunique.
Run a search narrowed in their wheels/tire/suspension section
search for developing camber
That should bring up his thread. He is basically doing this out of his garage, so some of his delivery times haven't been spectacular. But the product he delivers makes the other products take a back seat. I'd buy his camber kits way before any other companies.
Ivry 6mt sed
Crawford Pleneum
Injen CAI
22" resonator
Cusco sway bars
350Z springs&struts
Enkei RPM2
Ivry 6mt sed
Crawford Pleneum
Injen CAI
22" resonator
Cusco sway bars
350Z springs&struts
Enkei RPM2
isnt the front adjustable? or is it the rear? i remember reading that for the sedan, you only need one set. or i could have dreamed it. anyone wanna set it straight?
G35S 6MT
K&N Typhoon intake
Technosquare ECU
350Z Springs & Struts (soon)
6-wire ground kit
G35S 6MT
K&N Typhoon intake
Technosquare ECU
6-wire ground kit
Would running 19s cause such problem? From my knowledge, camber kits are pricy like hell. I used to have such problem with my lowered benz and I spend couple hundred on those camber kits and they still didn't do the job (well corrected a bit at least). But still I couldn't get recon because of the off alignment. I might get 19s and not lowered if that is ok. If not, I'd just stick with the stock spec. Just my .03 cents.
2004 G35 Coupe 5AT
Black/Graphite Ltr
Tire Pkg
2004 G35 Coupe 5AT
Black/Graphite Ltr
Tire Pkg
