Fender rolling question for 19x9.5 +29
Old Jan 24, 2007 | 09:16 PM
JZ39's Avatar
I just got my Volk Winnings in 19x9.5 in the rear with a +29 offset and 275/35tires.
I know that this is a super common wheel size, but it looks like the tire would rub the fender if the spring were compressed.
I don't recall anyone talking about rolling their fenders with this wheel/tire size.
Can someone chime in and let me know the deal?
Old Jan 24, 2007 | 09:22 PM
redlude97's Avatar
I've got a 19x9.5 +30 wheel with a 285/35/19 which doesn't rub. You have to remember that the suspension doesn't compress straight up, but rather in at an angle so the wheels will clear. Try placing your jack underneath the springseat and jacking it up to clear, but I'm pretty sure you won't rub with that size. People run 10.5 +25 and still don't rub, which is 17mm further out away from the hub.
Old Jan 24, 2007 | 09:46 PM
superdds's Avatar
i'm lowered and have volk gtc 19x9.5 +24 with 275/35 in the rear with no rubbing issues whatsoever...should have gone with 10.5. damn!
Old Jan 25, 2007 | 12:15 AM
kenchan's Avatar
you'll have plenty of clearance with a 9.5" +29 from the negative camber.
im running +26 10" width 275/35/19 and still have probably 7-8mm to
spare.
Old Jan 25, 2007 | 01:00 AM
redlude97's Avatar
IMO you should roll them anyways and get some spacers, those wheels are going to be kinda sucken in. Thats what I plan on doing with mine. Hoping to end up at 9.5 +5 with a 285/35/19
Old Jan 25, 2007 | 01:46 AM
Calvin's Avatar
Overglorified Altima
you shouldnt need to roll them..
i'm 10.5" with +24 and 285 and i would just barely rub (dropped on a z h techs)
Old Jan 25, 2007 | 07:17 AM
JZ39's Avatar
Awesome. Thanks for the replies.
I was thinking that the suspension doesn't ride straight up as well.
The wheels are actually quite flush and not tucked at all. I'll post pics once I get a set of friggin' lugnuts that fit these wheels! The waiting is killing me!
Old Jan 25, 2007 | 12:53 PM
redlude97's Avatar
I don't think you've actually seen "flush" wheels yet, because I know from personal experience that 9.5 +29 isn't flush, its at least 10-15mm from being flush. I run a 9.5+30 with a 285/35/19 and its not even close to being flush.
obender66
18 Inch
Mar 13, 2016 12:20 PM
Tylerttn
Aug 10, 2015 07:13 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Popes
Jul 29, 2015 05:07 PM
Soumilg
Jul 18, 2015 12:33 PM
