i just bought tires but im confuxed!
Old Mar 31, 2007 | 07:56 PM
Beebo's Avatar
i just bought tires but im confused!
i just bought TOYO T1R'S for my stock 19's. first i get to the shop and they only have the two fronts. im confused because i have the 19x8.0 fronts and 19x8.5 rears. the stock rears have really no tread on them. are these numbers right on the rear OEM tires say 245/40/19and the new TOYO's in front say 245/40/19/ is that right for the 8.0 and 8.5 sorry im so lost please help me AND WHAT ARE THE STOCK SPECS?
thanks
Old Mar 31, 2007 | 08:03 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
i'm confused now too, i dont understand anything i just read.. sry bro.
-GP-
Old Mar 31, 2007 | 09:10 PM
mondo's Avatar
I think those tires are too tall...
I just put on new Toyo T1Rs on my stock 19s last month. I put on 245/35 on front and 275/35 on the rear. There's been a little controversy on this site going back and forth on this size as they're wider. But the tire shop had no problem and they look/ride great. These give a very close to correct speed too.
Old Mar 31, 2007 | 10:39 PM
jameyb's Avatar
If you are asking about the OEM tire size for the 19" coupe wheels they are:
225/40/19 front and 245/40/19 rear.
Old Mar 31, 2007 | 10:55 PM
BadBoy06's Avatar
-GP-
same here..what did he say
Old Apr 1, 2007 | 12:16 AM
Beebo's Avatar
i just bought new tires. i only got two for the front the rear are still the stock tires. the 19's are 8.0 front and 8.5 rear but the new toyos are the same size as the rear 245/40/19/ is that bad
Old Apr 1, 2007 | 03:25 AM
G SEDAN's Avatar
no its not bad....you're just running the same size all around now is what you're saying? no more stagger tire set up?
Old Apr 1, 2007 | 03:29 AM
Beebo's Avatar
^^ but what about the with of the rim fronts and rear have the same numbers so 8.0 and 8.5 dont matter?
Old Apr 1, 2007 | 11:46 AM
GuyLegend's Avatar
A wheel width has a range of tires that can fit. A 245 tire will fit fine on a wheel 8 or 8.5 wide.
Old Apr 1, 2007 | 12:18 PM
Beebo's Avatar
^ thanks
Old Apr 1, 2007 | 10:53 PM
Beebo's Avatar
bump
vitamin.v
Nov 7, 2019 06:10 PM
Jnm07
Aug 6, 2015 03:03 AM
bjo16
Aug 4, 2015 09:52 AM
