Tires for OEM 19s : The end-all thread
Old Jun 12, 2009 | 06:40 AM
  #286
terps's Avatar
235/35 & 255/35? thanks
Old Jun 20, 2009 | 12:11 PM
  #287
mel1mls's Avatar
Previously in this thread there was some talk about 19" coupe wheels on a sedan. I'm not sure if I am understandibg the answer correctly. Will these wheels cause VDC problems on my 06 sedan? I really love these wheels and would like to you run them?
Old Jun 20, 2009 | 04:07 PM
  #288
Canuck's Avatar
I have a 2006 G35x and I run the 19" coupe wheels with no problems. I put 245/40R19 Yokohama s.drives on all 4 wheels. I have had no problems with the AWD or the VDC. Could be that I am running the same size tires all around.
Old Jun 23, 2009 | 10:30 PM
  #289
mel1mls's Avatar
Same size tires would be fine with me, but what if the set of rims I buy have the 225 front/245 rear combo? Can i use those or do I have to change the tires out immediately?
Old Jun 26, 2009 | 10:35 AM
  #290
Swivel's Avatar
Moderator
Has anyone run 255/40 all around on a sedan? From my research on tire calculators, it looks like they'll fit fine on both 9" and 9.5" wheels, and they are only slightly larger (27" vs. 26.3", or less than 3%) than my stock 17 size. Would I notice a difference in the sidewall angle from front to back?
Old Jun 26, 2009 | 10:42 AM
  #291
Jeff92se's Avatar
Red Card Crew
I think if you run a 255-40 on a coupe 19, you run the risk of rubbing. It's one reason I went with a 255-35. I think a 245-40 all around might be a better choice.
Old Jun 26, 2009 | 10:46 AM
  #292
Swivel's Avatar
Moderator
Yeah, but I can't get four of those in Falken 452's, practically new, for $400! LOL.
Old Jun 26, 2009 | 02:13 PM
  #293
Jeff92se's Avatar
Red Card Crew
I ran the 245-40-19 RE050 before getting the michelins. I don't know if it was the weight diff or the size diff but I could actually notice a diff in accerlation. Granted, I saved 3-4 lbs off each rear tire and the dia diff of a 255-55-19 is 2.6%.
Old Jun 26, 2009 | 07:09 PM
  #294
G35MR2's Avatar
I went to install a set of 275/35 BRIDGESTONE POTENZA Run-flats today on the rear and the tire shop couldnt get it to hold air. Is this because they aren't track tires and can't take the bulge? I have found someone that I can trade for a set of Toyo T1-R's. Would they work better? Thanks for any help offered.
Old Jun 27, 2009 | 08:31 PM
  #295
truexh's Avatar
how come everyone is doing 245/35/19 front and 255/40/19 rear instead of 245/40/19 front and 25//40/19 rear? wouldn't we want to keep it at 40 for better treadwear?
Old Jul 14, 2009 | 12:46 PM
  #296
Swivel's Avatar
Moderator
I know somebody with a fender roller...
I had a full set of 245/35s lined up and then the bastid welched...
Old Jul 15, 2009 | 07:32 AM
  #297
cicada06's Avatar
Originally Posted by LightsOut
245/35 255/40
but now im rolling 20f/r25mm spacers along with my tire setup
Do you have any rubbing issues? Thinking about going wit the same set up but i'm also lowered on Z H-techs.
Old Jul 15, 2009 | 11:54 AM
  #298
LightsOut's Avatar
SIETESG
H techs sit pretty high in the back so you wont have any rubbing issues, but if you to lower the back or have rear passengers you migh get slight rubbing, unless you rolled your fenders then there wouldnt be any issues.
as of now Im running Z-RSR down springs and rolled my fenders.
Old Jul 15, 2009 | 11:33 PM
  #299
skahide's Avatar
ok so i have a coupe & installing oem 19's. Been riding on 17's with Tanabe 350Z GF210's (about 2" drop all around). Hope to add spacers in the future, BUT what tires sizes should i go for right now, with the drop i have?
Old Jul 15, 2009 | 11:39 PM
  #300
Invalid_User's Avatar
What about
225/40/19 and 255/40/19
WOuld i have any problems running these sizes?
