Tires for OEM 19s : The end-all thread
Old May 17, 2010 | 04:41 PM
  #466
TechCase's Avatar
Originally Posted by LightsOut
go with the 245/255 combo.
Thanks for the help. But even that I'm still confused and sort of leaves me with my original question about 255/35 vs. 255/40...
245/35(F) 255/35(R) like DjGenuine and SwivelHips are running/will run on?
245/35(F) 255/40(R) like csfender125 and tmounk were contemplating?
Plus a brief explanation of why would be greatly appreciated
On a side note, I'm assuming more contact patch in the front will reduce inherent understeer, but do you guys notice a noticeable decline in mileage w/ wider tires?
Old May 17, 2010 | 05:05 PM
  #467
LightsOut's Avatar
SIETESG
255/40 has a larger wall
255/35 has a lower wall.
if you're on stock height or moderate drop, then you'll want a larger wall to help reduce wheel gap. If you're lowered a lot, then you'll want a lower profile to prevent rubbing.
dont get the sedan guys confused with the coupe guys. Some who have posted tire sizes are sedan guys with coupe 19's; so their tire size will be slightly different.
wider tires will have more grip but not by much compared to oem sizes. mpg will stay as current.
Old May 17, 2010 | 06:20 PM
  #468
The Stimulation's Avatar
Don't forget the brand of the tire makes a difference too. Just like shoes they run small, large, and true.
Old May 19, 2010 | 01:53 PM
  #469
cpufreak3's Avatar
What do you guys think about:
245/40/19 - front
275/35/19 - back
Will I rub in the back on stock height, no spacers?
Old May 19, 2010 | 01:56 PM
  #470
LightsOut's Avatar
SIETESG
please post up widths and offsets.
oems sizes?
Old May 19, 2010 | 02:07 PM
  #471
herrschaft's Avatar
245/40/19 - front
275/35/19 - back
I'm assuming you have OEM 19's. People have done 275's before, but I wouldn't risk going that wide on the rears. I doubt you'll rub.
Old May 19, 2010 | 02:53 PM
  #472
cpufreak3's Avatar
oems sizes?
Yes, OEM 19s (rays).
What's the risk in 275s? VDC problems?
Old May 19, 2010 | 03:41 PM
  #473
LightsOut's Avatar
SIETESG
its not vdc problems, it's running a too wide of a tire on a narrow wheel. some have it on this site, but I for one will never risk it.
Imagine taking a turn then seeing your tire roll past you..lol thats what could happen.
Old Jun 19, 2010 | 06:54 PM
  #474
Xet's Avatar
Xet
Anyone stretching their front tires? I'm pretty low on coilovers and stretching would greatly help to reduce my rubbing and let me get closer to spec for camber, so I was wondering what others have done to downsize the tire a tiny bit...
Unfortunately I replaced my rears with 255/40/19 a bit before I got coils so those are a bit larger but I'm not going to replace those when they are brand new.. so I'm just looking to help out in the front.
Old Jun 23, 2010 | 06:07 PM
  #475
BillBradley's Avatar
Question for those with sedans and OEM 19's.
I have an 08 IP sedan that came with 17" and upgraded it to OEM 19" G37S coupe wheels and tires. The standard were 17-inch aluminum-alloy wheels with P225/55VR17 all-season tires, which I run in the winter here in North Carolina.
Here are the specs for the coupe wheels:
*Fronts are 19x8.5 Offset +43
*Rears are 19x9 Offset +45
with FR 225/45R19 92W; RR 245/40R19 94W, summer tires .
I would like to upgrade the tires to Hankook Ventus V12 EVO K110, fronts 245/35zr19 and rears 275/35zr19. Will these fit with out problems? I had check the sizes with the oem G37s tires and they were very close. The car is not dropped and I have no plans at this time to do a drop.
Thanks for your input, I need tires soon... I like the grip of the Potenza RE050's but hate the noise.
Old Jun 24, 2010 | 12:51 AM
  #476
herrschaft's Avatar
^Those widths should fit fine. Use this link to see if the tire sizes will work:
http://www.miata.net/garage/tirecalc.html
Old Jul 8, 2010 | 12:53 PM
  #477
G35fromPA's Avatar
For those who have gone from OEM 19" tire sizes (225/40 and 245/40) to wider (e.g. 245/35 and 255/40 or 265/35) what has been the penalty in terms of ride quality? Is it noticeable?
Old Jul 12, 2010 | 12:32 AM
  #478
SacG35's Avatar
does anyone have PICS of 245/35/19 on Rear 19s OEM Rays?
Old Jul 14, 2010 | 02:37 AM
  #479
code2424's Avatar
Hey I am currently running 235/35/19 on the front and 245/40/19 on the rear. I want to put on 255/40/19 on the rear. You guys think it will be good set up with the front?
Old Jul 17, 2010 | 05:53 PM
  #480
G35fromPA's Avatar
What about:
235/40-19 F
255/40-19 F
Tire calculator shows each is 1.2% bigger than OEM sizes, so the total diameter difference front to rear (from OEM sizes) is zero. Should be fine with VDC, right? Will taller sidewalls lead to softer handling?
