Tires for OEM 19s : The end-all thread
Old May 6, 2010 | 05:38 PM
  #451
Grevving6's Avatar
Originally Posted by FenixL1P
It's weird what you coupe guys do the your rides.... reversing your staggered fit wheels and tires just so you can get more life out of them? Might as well get the same rim size all-around, cause you are defeating the design intentions of the staggered setup. To each his own. Have fun and enjoy your rides.
Yeah well thats what happens when your car comes stock with OEM Rays--19inch wheels! This seems to be the only way to wear them out evenly
Old May 6, 2010 | 05:42 PM
  #452
blaccG35's Avatar
i recently just got new tires...and i did 245/35 F and 255/40 R and i can diff. feel the differences from how the car feel now...alot more grip then oem size
Old May 6, 2010 | 05:50 PM
  #453
Swivel's Avatar
Moderator
^^ Probably more the effect of new tires.
Old May 6, 2010 | 05:53 PM
  #454
blaccG35's Avatar
^ probably cause my old tires were bald as crap
Old May 7, 2010 | 04:19 AM
  #455
herrschaft's Avatar
Yep.
Besides, the stagger is too small to even notice a difference.
Old May 7, 2010 | 11:30 AM
  #456
DjGenuine's Avatar
Im about to order some tires for my stock 19" wheels...
Bridgestone Pontenza RE-11
245/35/19 for the front
255/35/19 for the rear
any you guys see any issues with these sizes.
thanks.
Old May 7, 2010 | 11:56 AM
  #457
herrschaft's Avatar
^nope
Old May 10, 2010 | 09:54 AM
  #458
lag35driver's Avatar
BMW
It is possible to run 275 / 40 / 19 on OEM 19"? I am currently running 255/30 and I am having a hard time going up my driveway without hitting my exhaust. I am lower with TB.
Old May 10, 2010 | 10:07 AM
  #459
Swivel's Avatar
Moderator
thanks.
Those sizes are what I run on my sedan and very happy with the look.
Old May 17, 2010 | 03:03 PM
  #460
TechCase's Avatar
So between 255/40 and 255/35 (rears), which one is less likely to throw off VDC, or are they about the same? (and which is more preferred?)
Old May 17, 2010 | 03:20 PM
  #461
herrschaft's Avatar
What size are your front tires?
Old May 17, 2010 | 03:31 PM
  #462
LightsOut's Avatar
SIETESG
neither. Are you dropped low? if not, then go 40 wall
Old May 17, 2010 | 03:33 PM
  #463
TechCase's Avatar
I'm not dropped yet (don't plan on dropping too low anyway) and my fronts are stock size 225/40, although I am considering 235/35 for the fronts as well
Old May 17, 2010 | 04:06 PM
  #464
LightsOut's Avatar
SIETESG
go with the 245/255 combo.
Old May 17, 2010 | 04:07 PM
  #465
The Stimulation's Avatar
Hrmm... deciding whether to run 215/35 all around, 215/35 (F) and 225/35 (R) or 225/35 (F) and 235/35 (R). Gonna need 25, 30, or 38 mm spacers all around to sit flush. Depends on the tire I go with.
