Tires for OEM 19s : The end-all thread
Old Mar 23, 2009 | 07:59 PM
  #106
eurodre's Avatar
wut about 245/35/19 all around on a coupe? no vdc issues or anything right?
Old Mar 23, 2009 | 08:12 PM
  #107
Beebo's Avatar
You should be fine, i have 245/40/19 front and rear and have no problems
my next tires will be 245/35/19 front and 255/40/19 rear
Old Mar 23, 2009 | 08:16 PM
  #108
eurodre's Avatar
woohoo, cus i wus gonna get the oems (225/40/19 and 245/40/19) BUT as i found out falken doesnt MAKE 225/40 and i wasnt gonna go with a 225/35
Old Mar 24, 2009 | 12:17 AM
  #109
rob40wilson03's Avatar
i have 245/40/19 kumho ecsta spt's on the rears and the fronts need to be replaced... i think im gonna go with the 245/35/19 kumhos.... all thanks to this thread..... i was gonna get the 225's but it seems like the 245's will give me less understeer, correct???
and are there any negative effects of getting the wider fronts?
Old Mar 24, 2009 | 12:24 AM
  #110
Beebo's Avatar
why would you get wider fronts?
Old Mar 24, 2009 | 01:35 AM
  #111
because, like i said.... people have said that it will reduce understeer
Old Mar 24, 2009 | 01:47 AM
  #112
Beebo's Avatar
245/35/19 is what you want
Old Mar 24, 2009 | 12:03 PM
  #113
so is there any downside to having wider fronts?
Old Mar 24, 2009 | 01:08 PM
  #114
scotts04MT6's Avatar
As long as you pay attention to what you have on the rear - no.
Old Mar 24, 2009 | 01:51 PM
  #115
redlude97's Avatar
that is a horrible choice for a coupe
Old Mar 24, 2009 | 01:53 PM
  #116
eurodre's Avatar
^^howcome?
Old Mar 24, 2009 | 02:20 PM
  #117
redlude97's Avatar
the rear is way too short. It will cause your speedometer/odometer to be off, and likely cause VDC issues
Old Mar 24, 2009 | 02:34 PM
  #118
eurodre's Avatar
so wut about a 245/35 and 245/40, should be better?
Old Mar 24, 2009 | 02:46 PM
  #119
redlude97's Avatar
yes
Old Mar 24, 2009 | 02:50 PM
  #120
eurodre's Avatar
just exploring my options, wut a 235/35 be fine as well? its slightly bigger than the 225 oem
