Shaky car after new wheels?
Old Aug 10, 2007 | 09:55 AM
oneshot's Avatar
So I put my rims on about a week ago. I went with a 19" Sevas S-Star. 19x8.5 front, 19x9.5 rears. I used the stock tires. They are not the "proper" size for the wheel but they fit fine. They are a little stretched though.
My problem is this, when I hit 70-80, the car starts shaking like crazy. It used to be a lot worse but I got hubcentric rings (73>66.1) and hoped that would fix it. The car still shakes. I am probably going to take my car back to the tire shop on Saturday to get it looked at. He said it could be a balancing problem.
Could it be a balancing issue? Is it because the tires aren't the "right size"? I am doing perf. mods to my car but if the car is not safe to drive past 70, I need to get this taken care of. Hell, I'll go back to stock wheels if need be. Post up anything you think it might be.
Old Aug 10, 2007 | 10:00 AM
binar's Avatar
Have your wheels balanced.. again. That is most likely the problem. You could have an 'out of round' tire, that would be bad. But that will show up when they balance the wheels. Good luck.
Old Aug 10, 2007 | 10:09 AM
oneshot's Avatar
Will they be able to tell right away if I have an 'out of round' tire? My right rear tire had a nail in it and they fixed it when I got the wheels on. The guy at the tire shop seems to know what he's doing so I dunno
izmir41500's Avatar
G35driver Addict
+1 get them rebalanced.
Old Aug 10, 2007 | 10:26 AM
JOKER's Avatar
CLUB MODERATOR
what about hub centric ring?
Your wheels could be off center.
Old Aug 10, 2007 | 10:32 AM
oneshot's Avatar
I already put hubcentric rings on.
Old Aug 10, 2007 | 10:41 AM
G35SHAWN's Avatar
May need to rebalanced, but then again check the tire pressure cause after all you're not going with the proper size tires, so i am guessing perhaps that's were is the problem is.
Old Aug 10, 2007 | 10:45 AM
oneshot's Avatar
I checked pressure at the gas station yesterday. Most of the tires were at about 25-28psi. The back right was kind of low, I think it was at 25 or just below. My TPMS keeps going off to. I don't think they fixed the tire properly from the nail.
Old Aug 10, 2007 | 12:53 PM
Plat04G's Avatar
You should be up in the 30s, around 35. 25 is really low and that why ur TPMS keeps going off.
Old Aug 10, 2007 | 01:01 PM
MaidenG35's Avatar
That's strange. So you had no problem when you had your stock wheels on but now that you changed to 19's, your car shakes. Some people have said that when the tierods wear out, then your car starts to do that... https://g35driver.com/forums/g35-sedan-v35-2003-06/150749-vibrating-over-80mph.html
Looks like your lowered on s-techs..how long have you been lowered? Maybe the shocks are starting to give?
Old Aug 10, 2007 | 01:14 PM
oneshot's Avatar
Originally Posted by MaidenG35
That's strange. So you had no problem when you had your stock wheels on but now that you changed to 19's, your car shakes. Some people have said that when the tierods wear out, then your car starts to do that... https://g35driver.com/forums/showthread.php?t=150749
Correct, no problems when I had the stocks on. It only started doing it the day after I put the wheels on.
I actually read that thread this morning. I got my car in April, I really hope the tire rods aren't worn out already I don't even have 3500 miles on it yet. My car isn't actually lowered yet, the springs are arriving on the 13th I had (On order) in my sig but I took it out.
Old Aug 11, 2007 | 07:10 PM
oneshot's Avatar
Got it fixed today. Turns out it was a balancing issue. Thanks for the help.
rezendvous420
May 31, 2020 01:26 PM
Brodys_GCoupe
Nov 7, 2015 08:06 PM
itschuckster
Jul 25, 2015 08:07 AM
Karnicle
Jul 23, 2015 05:08 AM
realtalk21
Jul 20, 2015 09:07 AM
