Tire size q... yes I have searched
Old Nov 25, 2007 | 12:43 AM
MiloX's Avatar
Sorry guys. I usually spend most of my time over in the Audio forum.
I have searched, and I cannot seem to find what I am looking for.
I am planning on getting new wheels (TSW Mondello's 19x9.5 all around).
Can I run 255's up front? I'd like to keep the same size tires for rotating.
I am dropped on Z-Springs with the factory 18's.
Thanks again!
B
Old Nov 25, 2007 | 12:46 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
not gonna happen. With a 9.5" wheel up front you'll need to stretch the tire. Also depends upon the offset of the wheels.
-GP-
Old Nov 25, 2007 | 01:40 AM
GeeDM's Avatar
You should rock a 8.5/9.5 like most sedans do. Well i guess you could run a 10 in the rear depending on the offset...who cares about rotation..hahahah..
Old Nov 25, 2007 | 09:13 AM
MiloX's Avatar
Cool. Thanks.
The next size down is 8. I guess that means 8" up front and 9.5" rear... ok.
Soooo..... 245/35-19 on the front and 275/35-19 on the rear?
45mm offset for the front 8" er?
Thanks again guys.
Old Nov 25, 2007 | 03:15 PM
what's the offset on the Rear??? you could use the 45mm offset up front but i'd definitely get a 10-15mm spacer. You can run a 275/35 rear tire only if the offset is around 40 and you roll your fenders.
-GP-
Old Nov 25, 2007 | 03:25 PM
ttrank's Avatar
Grocery getter
+1 on the spacer for the front. I would get a 10mm spacer on the front and a 5mm for the rear (if the rear is a +45). Or you might be able to run the +45 rear without rolling your fender.
Old Nov 25, 2007 | 08:34 PM
MiloX's Avatar
I was looking at a 19x9.5 35mm for the rear.
I am ok with rolling the fender if I need to.
Old Nov 25, 2007 | 10:01 PM
MiloX's Avatar
-GP-
So an offset of 35 is too aggressive for the rear?
Old Nov 26, 2007 | 08:20 AM
AS007's Avatar
I am dropped on Tein S-tech springs, with 245/35/19 in the front and 285/30/19 in the rear and no rubbing at all.
Old Nov 26, 2007 | 10:00 AM
da mayor's Avatar
i had a 20x10" rear w/ a 42mm offset... it rubbed w/o rolling my fenders... then rolling the fenders took it all away.
i had a 38mm offset in the front on a 20x8.5 w/ 245/35/20 and it rubbed going up driveways
Old Nov 26, 2007 | 05:29 PM
MiloX's Avatar
Thanks everyone.
I *think* I have the info I need. Just to be clear... here's what I think I learned from ya'll today:
F 19x8 +40 with 5mm Spacer on 235/35/19
R 19x9.5 +45 on 275/35/19
OR
R 19x10 +45 on 275/35/19
Correct?
Old Nov 26, 2007 | 05:54 PM
Dan in St Louis's Avatar
Originally Posted by da mayor
Hmm, are somebody's tires mounted backwards?
Old Nov 27, 2007 | 03:45 PM
MiloX's Avatar
So what do you guys think?
OR
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
Jnm07
Aug 6, 2015 03:03 AM
reaper76
Aug 5, 2015 10:13 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
