Tein Flex or Type CS
Old Mar 8, 2004 | 11:28 PM
R2 V35's Avatar
Fellas! need your help again in making a big decision. Should I go for the Flex or CS. Does anyone have the Flex or CS on their G?...Help me out here! Thanks in advance......
6MT Ivory/Willow>>Nismo OEM Kit>>Premium Package>>XM
"Tell all my people i'm a Ridah, Nobody cries when we die, we outlaws, let me ride"
Old Mar 9, 2004 | 07:27 AM
ProDrift's Avatar
Re: Tein Flex or Type CS
I have the Tein flex on my sedan and that is my vote. INCREDIBLE!!!!!!! The CS doesn't have as much adjustability, EX: my car is lowered and still has the stock suspenion travel length. Do look at my post in this section titled: I painted my rims... you can see pics of the car there. Keep in mind the ground is not exactly level.
Old Mar 9, 2004 | 07:29 AM
ProDrift's Avatar
Also read the "Best shocks and sway bars..." post on Fresh Alloy. That will REALLY enlighten you.
Old Mar 9, 2004 | 09:27 AM
R2 V35's Avatar
Thanks ProDrift!, that will help..by the way should I call you Mr. SleeperG?..
Old Mar 9, 2004 | 01:24 PM
Gsedan35's Avatar
Orginally posted by:
fXg35rIdA
"Yes thats what I'm looking for..Comfort and adjustability, I have a little girl so I need my ride to be as comfortable as a stock ride..Thanks for the advise!"
Tein's Flex system is part of their performance line and use's spring rates and dampner valving accordingly. Let's look at those spring rates.
My oem rate data has recently changed, I have not gotten my hands on a set of oem sport sedan springs to recheck, but the previous data was hardly different than coupe rates. So for the sake of comparision, I'll use the new coupe data. (I do have up to date non sport rates).
Oem spring rate
314lbs/342lbs
Tein Flex
672lbs/672lbs
Percentage of stiffness vs oem: +114% front +97% rear
Transfers +17% roll stiffness to front
Dampner valving biased to performance, to handle given spring stiffness (or known positive owner review's would not exist given those spring rates) Dampners are adjustable, and have a adjustment (or control) range where the dampners behave as if they were controlling 560lbs springs using the softest settings, all the way up to 784lbs springs at the firmest settings.
Tein CS
392lbs/392lbs
Percentage of stiffness over oem: +25% front +15% rear
Transfers +10% roll stiffness to front
Dampner valving biased to comfort.
Dampners are adjustable, want to say adjustment range in the lower setting act's to control 280lbs spring rates and 504lbs spring rates in the higher settings. Lowest control range if I'm wrong would be 336lbs and 448lbs accordingly.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Mar 9, 2004 | 02:17 PM
weslutes's Avatar
Tein Basic 504/504 Right?
Dark Side Of The Moon
Old Mar 9, 2004 | 02:37 PM
THX723's Avatar
G Kreuzer
If you're looking for something close to the stock ride quality, then you may be disappointed with the 'current' Type Flex. It is very harsh!
Be careful when you ask for feedbacks from past Type Flex owners, as there have been at least two revisions out there with different spring and damper rates. The most current being the most aggressive at 12-kg/mm (671 lb-in).
Type CS would be your best bet, if 'comfort' is paramount.
Clint (THX723)
Old Mar 9, 2004 | 03:36 PM
ProDrift's Avatar
I'm learn2turn on FA and I have the new Tein flex (stiffer).
12kg
Chris Ressler
PasSport Infiniti - Quality Control Manager
Capital G club - President
** Your friend on the inside **
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Video Share
Jan 31, 2017 04:00 PM
