Aftermarket Rim Problems Need Help Asap
Old Jan 22, 2008 | 06:00 PM
delsap's Avatar
I have a 2003 G sedan 5AT and just recently put a set of 2007 nissan 350z rims and tires which fit the car fine but I am having prolems with the ABS and VDC. I was told by a nearby nissan dealership that the reason i am having trouble is because you cannot put staggered rims on the car. I am in a very tight situation with money and really can't afford to even buy back a set of stock rims. Anyone who knows anything that could help would be greatly appreciated
Old Jan 22, 2008 | 06:03 PM
redlude97's Avatar
Install the same sized tires on the front and rear of the car even though the wheels are different widths. Try and match the 215/55/17 tire size
Old Jan 22, 2008 | 07:21 PM
Chico's Avatar
most of us run a staggered set up on our sedans without any problems, so we know that is NOT the issue.
To help you better, we need more info from you.
what are the tire sizes on your new wheels?
is your car AWD?
Old Jan 22, 2008 | 07:23 PM
delsap's Avatar
Right now I have 225/45/WR18 in the front and 245/45/WR18 in the rear, would i be able to put 245/45 on the front? The dealership told me that my car was sensing the rear wheels moving about 4mp/hr faster than the front if that helps at all. The only idea they had would be to replace them with the stock ones which i dont have anymore.
Old Jan 22, 2008 | 07:26 PM
delsap's Avatar
Rwd
Old Jan 22, 2008 | 07:28 PM
Jeff92se's Avatar
Red Card Crew
You shouldn't have problems. I run coup 19s with the same stagger %. 225-40-19 and 245-40-19 and have not run into any VDC lights or etc..
Old Jan 22, 2008 | 07:34 PM
delsap's Avatar
I know i just talked to the garage that put the rims on and they told me that the reason the VDC was being turned off was because the steering alignment sensor needed to be reset using a factory computer. I brought it to a Nissan dealership because the nearest Infiniti one is about two hours away but that seems like my only choice
Old Jan 23, 2008 | 08:55 AM
delsap's Avatar
Does anyone know if I could have my ECU reprogrammed to solve the problem? Thanks for any input I am pretty much screwed if I can't solve this on my own.
Old Jan 23, 2008 | 08:58 PM
JessNherG's Avatar
Was nissan able to reset it?
Old Jan 25, 2008 | 11:22 AM
delsap's Avatar
They told me that my car can not work with staggered rims which I know is not true
Old Jan 26, 2008 | 09:04 AM
OCG35's Avatar
Edit: Previous post read wrong... you are 1.6 mph faster - which from what I have read should be within tolerance
http://www.miata.net/garage/tirecalc.html
Old Jan 26, 2008 | 04:12 PM
DaveB's Avatar
I'm surprised not a single person has caught this. His tires are way mismatched. A 225/45R18 is ~25.9" tall and a 245/45R18 is ~26.7" tall. That's a very big difference. The correct tire for that back should be a 245/40R18 (~25.8" tall).
Old Jan 27, 2008 | 11:50 AM
delsap's Avatar
If that is all thats wrong that would be great i bought these rims and tires already mounted through this site. Guess i didnt think to make sure the right tires were on the rims. Thanks for the help.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
BlackGee35
Jul 23, 2015 01:36 PM
EasySausage
Jul 14, 2015 11:17 PM
