Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#1576
The stretch won't be exactly even but it's much better than 225 front and back and will give you a little extra ground clearance up front.
I strongly suggest you run a little more camber though going with the +17
Here, this is Viveks old set up
the offsets are
Front 9.5 +4
Rear 10.5 +17
Camber is about -3ish in the back
Tires are 225/35 and 235/35 I believe.
the offsets are
Front 9.5 +4
Rear 10.5 +17
#1577
YES!!!!!!!!! THANK YOU!!!!!! JUST WHAT I NEEDED!!!!!!
so now im thinking this would be a little too agressive for my taste (too much pokage) i like the stretch look.... this is hard man!
I dont know what to do. Im sure on the fronts im set there. its just the back im completely lost. Maybe i need to go a step back and get more conservative offsets?
I am following this chart here and looking at the Odisk section
http://www.workwheelsusa.com/media/w...5/VSXX_PDF.pdf
What i can do is get the fronts 9.5 +29 (84mm lip) and add a 15mm spacer
and have the back 10.5 +29 (97mm lip) (maybe 5mm?)
#1578
#1580
You could still go for a mild stretch and do 255/35 rear and 235/35 front.
Then run -2 degrees of camber, roll your fenders totally flat and add a small spacer in the rear and then what ever you might like in the front once the wheels are on the car.
would give you somewhat of a similar look to this
#1581
#1582
#1586
#1587
#1588
#1590
Hey guys, I just had a few questions about offsets.
If I'm planning to run 20s on my coupe, would the offsets 15F/15R rub at all?
Wheels are R1 Hype 20x8.5F, 20x10R
They'd be wrapped in 245/35 in the fronts and 275/30 in the rears.
Would they rub if I dropped them on 350z Htechs?
Also...this is probably a dumb question, but would 20s make my car look higher than on oem 19s? LOL
