Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Mar 1, 2011 | 12:24 AM
  #1516
chatt350gt's Avatar
Originally Posted by 4DGS
Found you someone.
Drew Turner
Deft Motion LLC
615-556-8276
Drew@DeftMotion.com
thanks man! i contacted him and he gave me a $80 quote to roll rears. the only thing is i have to drive 2 hours to get there lol i appreciate it!
the only thing that bothered me about ohella's fzero blue te37s was the front looked so much wider than the rears for some reason
Old Mar 1, 2011 | 09:52 AM
  #1517
R3N's Avatar
R3N
You're going to need a little more fender work than just a roll to be flush.
This is 20x11 -12 your set up will be 17mm less aggressive but this wheel is stretching a 235/35
His camber is about -3 if I recall and he had some room to play with the 235/35 (it was a test fit)
Therefore, you should be ok with the 275/30, -3 and go the rest of the way with fender work.
Thanks for that, I thought 275s wouldn't be too bad considering some of the guys are running 255s and 265s on 12. Hope to get away with -3.5 or -4 camber. Little poke is alright, but want 275s as a minimum. I did have a look through the thread but only found a few guys running 12" widths. I know the fronts will fit but just want to confirm anyway. They will be 20x10.5 +12 and probably going 245/35s
Old Mar 1, 2011 | 12:16 PM
  #1518
4DGS's Avatar
Originally Posted by quiksilver5
I want an all season tire. Summers where I'm at though can be pretty hot. What about Kumho or yokohama's or continental are those any good? I currently have Kumho they are good just want some additional recommendations.
All three are good choices, if you're going for a dedicated summer. Everyone on here seems to love the Hankook Ventus V12. They are priced well and are petty solid tires.
Originally Posted by gbert15
Yea its that! Its actually even on the sticky on here on aftermarket suspension and talked to b2autodesigns about it too! What do you mean by squishy then? Ive been looking into comfortable coils and I have 2 current options:
Bilsstein PSS10: 370 Front and 280(I think)-420 Progressive rear
Tein Comfort Sport: 390 Front and rear
Ok, you got them mixed up with spring rates in metric and imperial.
You said 5k they are actually 7k! The 392 is the spring rate in lb/inch and the 7kg is kg/mm
That's why I tripped when you said they were 5K, 5k would be a really loose and bouncy ride.
Originally Posted by B_Lam
hey,
have sf challenges 19x9.5 +28f (245/35/19) & 19x10.5 +23r (275/35/19). I'm planning to swap my springs to coilovers soon and to lower the car to at least no finger gap all around. I know the rears are going to tuck because as of right now i have 1 finger gap with -1 camber in the rear ( I set it like that when i had oem wheels). Now that i'm gonna go lower, i plan to set my camber a little more negative like at -2. My question is how many mm spacers should i get for the rear to flush it... also what negative camber do you suggest? Thanks.
If you go to -2 camber you can probably run a 15-20mm spacer as long as your fenders are rolled properly.
You definitely need to roll your fenders though.
Originally Posted by D.Reaper
so i got myself some 19" axis pentas, and i noticed the wheel bore is slightly larger than the hub bore...two questions, what is our stock hub bore, and where can i find out what the wheel bore is so that i can buy hub rings?
Nissan hub bore is 66.1mm
Axis penta hub bore is 73.1
So you'll need a 66.1 - 73.1 hub ring, they can be had on ebay for like $10 (for four) or like $20 if you go to a tire shop.
Old Mar 1, 2011 | 12:18 PM
  #1519
4DGS's Avatar
Agreed, not sure why that was.
The front will be fine.
What wheels did you pick anyways?
Old Mar 1, 2011 | 01:22 PM
  #1520
gbert15's Avatar
Ya, what i mean was stock springs of tein cs is 7k while they give me an option to go 5k without revalving! Theres a member on here that says that on stock it comes close to oem in terms of ride comfort so i was thinking of getting lower spring rate springs! Would going 6k still be unadvisable?
Old Mar 1, 2011 | 01:32 PM
  #1521
4DGS's Avatar
I personally would not go any lower than 7k, if you get even remotely flush you run the risk of eating a fender with that soft of springs. (unless you run some negative camber)
I don't think you'll be unhappy with the ride quality with the 7ks.
Old Mar 1, 2011 | 04:13 PM
  #1522
B_Lam's Avatar
Hey, yeah my rear are rolled. They were rolled by ShanesG... so it should be properly done lol. It was a mild roll though, not paper thin flat. Thanks for your help
Old Mar 1, 2011 | 04:27 PM
  #1523
4DGS's Avatar
well if you want to go more aggressive you can also give Shane a call to pull them!
Old Mar 1, 2011 | 04:39 PM
  #1524
B_Lam's Avatar
Lol true that! Adding 15mm spacers to the rear.. putting the offset at +8 with 275/35 tires is not considered more aggressive right?
Old Mar 1, 2011 | 06:33 PM
  #1525
4DGS's Avatar
Oh wait you have a 275/35 in the back?
Yea maybe make that a 10mm spacer lol my bad. 15mm up front though for sure.
Old Mar 1, 2011 | 09:17 PM
  #1526
gbert15's Avatar
Do u have any coilover recommendations? Most comfortable coils in the market right now so to speak other than tien cs and bilstein pss9/10? Looking currently for the best bang for the buck and im not planning to probably lower more than 1.5
Old Mar 1, 2011 | 10:28 PM
  #1527
DogStar's Avatar
BC Racing is typically best bang for your buck in general but Stance is super popular (and super out of stock for a lot of people too unfortunately...).
4DGS may have some other suggestions as well depends on how comfortable you really need/want it to be. PSS10 would be my choice if I had the cash. I'm in the market as well but want to get the front and rear camber kits as well (likely SPC or SPL... def not an area I want to cheap out on).
Old Mar 1, 2011 | 11:00 PM
  #1528
R3N's Avatar
R3N
If all goes to plan, will be a set of ADV1s off a 370
Old Mar 2, 2011 | 01:36 AM
  #1529
4DGS's Avatar
This is why I am making that coilover thread haha.
Check that out in the suspension area. There are quick reviews on several of the well known coilovers, but it just started so it's still growing.
I suggest SMA, mine have been great and ride amazing. Only reason I'm going to stance is because they didn't go low enough for me.
SPC not recommend, they tend to knock and make noise if you got fairly low.
Nice, can't wait to see em!
Old Mar 2, 2011 | 08:07 AM
  #1530
Duriisimo's Avatar
06 Sedan question
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
