Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#1426
RIM QUESTION!!!!
Lost some rivets for my rim... well the shop did while fixing the curb rash!
Im only missing 2 out of 10 but these aren't plastic these actually left holes in the rims!
I took them off and put my 18s on for now. My question is are they still safe to drive on? The shop guy said yes since its only 2 missing but he was kind of shady!
They didn't even charge me after I noticed they were missing.
Also can I replace em??? Anyone know how/where? Thanks
#1429
#1431
Hi everybody, my wheel set up is 20x9 +22 w/ 245/35 front tires and 20x10.5 + 35 w/ 285/30 rear tires.
My goal now is to make it look more aggressive, to do that I need you guys's input.
1) what coil-overs would you recommend, one that keep the ride smooth enough?
2) I'm not sure yet about spacers but I welcome any suggestions
3) how low should I lower it in order to look aggressive, well balanced and flash with fenders?
Thanks
Thanks
#1433
Thanks
Thanks
what are you trying to accomplish? you can run a large tire setup & a stretched tire setup. 255 F & 285 R easily.
#1434
Thanks
Thanks
2. I assuming this is a coupe? Front 20mm and rear 30mm if you're serious about getting aggressive lose those tires and run the biggest spacers you can find, then we'll talk tires.
3. What does this mean? Fender work? or???
option 1
18x10 front and 18x11.5 rear
option 2
20x8.5 front and 20x10 rear
regardless, I need to know if you're a coupe or sedan and the offsets on the wheels. If you're a sedan you need to research more.
#1435
#1437
I am wondering if this set-up will fit without issue.
05 Sedan with G/Z springs and Tokico shocks
19x9 + 35 front. 245/35/19
19x10 +45 Rear. 285/30/19
After looking at more set-up than I can count, and calculating tire diameters for almost every combo possible ive come up with the above tire combo.
I am not worried about the front, but I am uncertain about the rear fitting without rubbing. My fenders are not rolled as of right now, but im probably going to roll them a little (no pulling though).
Or I guess I should ask "what will it take for the rear to fit"
Im looking at Hankook v12's for tires.
Thanks.
Thanks.
So I really don't have time to go through 95 pages, so hopefully this hasn't been answered before... tried searching but couldn't find anything. The only thing I found said 20mm front and 25 mm rear... but that was someone with a 350z and anothers guess.
What I want is for the oem 18's to be as flush as possible with stock ride height and not have to worry about rubbing at all even under severe cornering. Which size spacers would you recommend?
25 front and back if you're not.
Looking for some advice on tire size for my G35 Coupe. I just got in my new wheels they are:
19x10 +10
19x11 +5
I was planning on using Falken FK452's but if someones got a better tire option I'm open, I need a mild to medium stretch. I was thinking about going with these specs but wanted to run it by everyone first so I only end up ordering tires once. My rear fenders are rolled and I'm on Stance Coilovers
Fronts:
245/35-19 or 255/35-19
Rears:
275/35-19
Any advice would be appreciated
19x10 +10
19x11 +5
Fronts:
Rears:
275/35-19
Those tire sizes will work, me personally I'd do 235/40 and 265/35 but or if you want to dump the car and be a man
235/35 and 265/30
Then add spacers and dial your camber.
oh forgot to mention DO NOT BUY FALEKNS. they stretch very poorly. Look into Hankook ventus v12s, Nankangs, toyos etc. Falkens bubble up really quickly.
#1439
#1440
