Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Mar 17, 2011 | 06:37 PM
  #1606
djfarhan's Avatar
hey what do i need to make this fit on a 07 X sedan?
Here are the specs:
2 front - 19x8.5 - Silver/Gunmetal Offset: ET-35
2 rear - 19x9.5 - Silver/Gunmetal Offset:ET-33
Old Mar 18, 2011 | 01:59 AM
  #1607
D.Reaper's Avatar
So i have an 06 sedan dropped on 19x8.5 +45 245/35 and 19x9.5 +40 245/35, i have the suspension at the lowest possible setting, im going tomorrow to have the rears rolled and will be cutting a portion of my spring mount to try to gain as much as possible...my question is: what sort of camber kit, toe arms, a arms should i be looking for, and what size spacers for a nice flush look (not looking for anything too aggressive) thanks in advance
this is how it currently stands:
Old Mar 18, 2011 | 06:09 PM
  #1608
4DGS's Avatar
Here are the specs:
Honestly, if you need to ask those probably aren't the wheels for you.
The front will be a bitch to fit since there is next to nothing to stretch on them. So say you go with a 215/35 (because there isn't anything smaller) you'll need a vicious phone book pull and -6 degrees of camber roughly...
The rear, you're going to need to flair flat (horizontal fender) and run around -9 degrees of camber with the same size tire (215/35)
What springs/coils? You probably won't need anything to adjust toe correctly. Get a rear camber kit. Ichiba or SPC work great.
As for spacers. I'd do a 20mm up front and a 10mm in the back. Ichiba V2s are suggested.
Old Mar 18, 2011 | 06:12 PM
  #1609
djfarhan's Avatar
^ thanks, i was looking at this.;-(
i so badly wanted to get these, too bad they are staggered...;-(
what rims are those?
  #1610
4DGS's Avatar
If you could find a really good wheel shop they could plug them and redrill them.
Old Mar 18, 2011 | 06:13 PM
  #1611
4DGS's Avatar
Wait, what are the offsets on those wheels before an adapter?
Old Mar 18, 2011 | 06:16 PM
  #1612
djfarhan's Avatar
^ on those bmw rims? i asked the specs on the rims to the owner and thats what i got was the original info i started with here
Old Mar 18, 2011 | 08:54 PM
  #1613
D.Reaper's Avatar
tein flex, no camber kit for front?
axis penta
Old Mar 18, 2011 | 08:59 PM
  #1614
4DGS's Avatar
Farhan, those are not the offsets on those wheels man. They're like +35 and +33.... not negatives. you can run those with WAAAAY less work.
Camber kits for the front are a waste, you can get pretty damn close to spec without having to buy a $350 front camber kit.
Old Mar 18, 2011 | 09:05 PM
  #1615
djfarhan's Avatar
well i told that guy to go ahead and take other offers, i dont know if they are gone already..;-(
Old Mar 19, 2011 | 03:09 PM
  #1616
4DGS's Avatar
Yea, I just checked, offsets are in the 30s.
Honestly, I wouldn't buy from him if he doesn't know the difference between positive offsets and a half width negative wheel.
Old Mar 19, 2011 | 04:25 PM
  #1617
usingthejohn's Avatar
Sorry I started a thread before looking into this one:
2005 g sedan
Front 20x8.5 +38. Will run a 20mm spacer for +18 offset
Rear 20x9.5 +45. 25mm spacer for an offset +20
Planned tire sizes: 225/35/20 front and 255/30/20.
Am I looking at the right sizes? Comparing The stock sizes they're very similar
Old Mar 19, 2011 | 06:32 PM
  #1618
by15vc's Avatar
^ Why the 35 series in front? Since you're not going for stretch I think you should run the 30 profile.
Old Mar 19, 2011 | 06:45 PM
  #1619
I'm trying to stay as close to stock as possible.
Old Mar 20, 2011 | 04:23 PM
  #1620
4DGS's Avatar
2005 g sedan
That works, but if you're lowered the rear will definitely rub without a little fender work.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
