Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Mar 22, 2011 | 04:55 PM
  #1636
SUPAH G 808's Avatar
hey guys, gotta question about my drop n rim fitment. SRRY IF ITS STUPID but i know nothing about this subject. i recently picked up tokico D-specs w/ tein s-tech springs for a 350z. considering i have a g35 the drop should b lower than on a Z. the rims i want to put on are 19x9.5 +17, 19x10.5 +22. so my question is, has anyone done somthing similar and could tell me wat to expect? ie do i gotta rollin fenders, stretch tire, +/-camber...etc. AGAIN im srry if its stupid and i appreciate all the help. THNX
Old Mar 23, 2011 | 12:49 AM
  #1637
4DGS's Avatar
First thing, what size tires do you plan to run?
Those specs are a pretty common set up.
The Z s-techs will drop you roughly a half inch lower than what Tein says they will drop the Z. (For example, if the box says drops the Z 1.5" expect a 2" drop)
For that set up, I recommend a rear camber kit to bring the rear camber in spec and then 245/35 (front) and 285/30(rear) tires. Rears I would recommend rolling but you could get away without rolling them if you let the camber go naturally and not adjust it into spec.
And this is the place for the "stupid" questions. I'd rather help you in here than for you to make a new thread asking the questions.
Old Mar 23, 2011 | 04:10 AM
  #1638
Affalterbach's Avatar
Got a question. What's the general consensus on wheel spacers? Good? Bad? The main reason I want to get new wheels is just so I can have a smaller offset thus making the wheels flush with the body, but that means 1000-2000$ in wheels just for looks.
If wheel spacers aren't that bad for the car, I may get some and just get the stock wheels painted black.
Old Mar 23, 2011 | 09:32 AM
  #1639
4DGS's Avatar
They're fine
Old Mar 23, 2011 | 10:55 AM
  #1640
djfarhan's Avatar
what do you think of the nardos?
so its between that and the asa gts,
whats the consensus guys?
Old Mar 23, 2011 | 11:44 AM
  #1641
4DGS's Avatar
What are he specs? I don't like the name of the Nards.
Old Mar 23, 2011 | 11:52 AM
  #1642
djfarhan's Avatar
this is the asa gt1 and the tsw nardo
wanna stick with 19s for both
Old Mar 23, 2011 | 12:04 PM
  #1643
4DGS's Avatar
Are the specs missing on the ASAs? Or am I just not seeing them somewhere.
The TSW come in a nifty 9.5 rear which is nice.
Old Mar 23, 2011 | 12:08 PM
  #1644
djfarhan's Avatar
what i found:
Offset: 40mm
Backspacing: 6.10"
Bolt Pattern: 5-120
Rec. Tire Size:225/40-18 (i will be getting 19s)
Weight: 25.6lbs.
Old Mar 23, 2011 | 12:22 PM
  #1645
4DGS's Avatar
I'd go with the TSW, slightly lower offset and better specs. TSW are higher quality wheels as well.
  #1646
djfarhan's Avatar
^ thanks! so far it is 4 for asa and 1 for tsw..;-/
Old Mar 23, 2011 | 12:38 PM
  #1647
4DGS's Avatar
But my opinion counts as 5 if I recall.
Old Mar 23, 2011 | 12:39 PM
  #1648
djfarhan's Avatar
right..;-)
Old Mar 23, 2011 | 01:56 PM
  #1649
GSoccer24's Avatar
I've done a lot of searching and using offset calculators but am having difficulty making a determination on this.
The setup:
F: 18"x8" +35, 225/50/18
R: 18"x9" +30, 245/45/18
The question:
Will the rear poke past the fender and/or rub?
Old Mar 23, 2011 | 02:37 PM
  #1650
4DGS's Avatar
Nope, you'll be nice and flush and problem free.
But I would suggest doing 225/45 and 245/45 (which is OEM sizing)
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
