Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#2297
Edit, 4D will know more about the front. You might be ok since you are probably going to be pretty low with those tire sizes.
#2298
If you want to keep that camber I'd run a spacer in the back.
The front will probably rub with that tire.
That setup is 11mm less aggressive than mine and I'm running -3.7 degrees up front with a 225/40 on untouched fenders, so you might be able to fit them depending on said pull but I don't think the 255 is going to be right for you.
[img][/img]
[img][/img]
#2299
#2300
I have been looking for the answer to my question in the offset section but have just gotten more confused. I am going to be putting HKS coilovers on my 03 Sedan and I want to get Varrstoen te37 replicas. I will be going 19x9.5 and 19x10.5. Will +22 be ok for me? I am not planning on slamming the car. I just want to drop it down some to try and get rid of some wheel gap. I do not want to run outside of the oem camber specs though. I would love for the wheels to sit flush with the car. Thanks for the help guys.
Also, what size tires would be ideal for this setup?
#2301
Here is my rear tire. 20x10 +25, -2.1 degree of camber with the fender rolled flat and a slight pull. (about 2" drop)
The wheel that you listed would stick out another 9mm from where mine sit. I would look for a wheel closer to 10" wide with an offset around +40 if you want to sit flush with stockish camber.
#2307
Im new with this offset this is my first luxuary car trying to go with a sick stance,I need some pointers.I have lexani lss-10 Front 8.5 rim with 245/35/20 tires and Rear is 10.0rim with 275/30/20 tires.I duno the off set.I want it to sit flush,what size spacers do u guys think i would need.Im gona be dropping it on bc coilovers here r some pic without the drop...
hope these help if not i can take better pic
#2308
#2309
#2310
Check your door jam, it will tell you the stock recommended tire pressure. Since you have wider tires you can run a little less pressure. What are your wheel offsets? Coupe or sedan?
